Hi all,
Been meaning to amp the speakers in the stag and ditch the stock ones in the rear for a while now but I just haven't got around to it.... Anyway time has come. Im not after anything ridiculously loud, just clear sound. Not keen for a sub as i use the wagon very often and dont want to mess about with a funky install in the floor or anything as thats time wasted on potential power gain fiddling....
Currently have a alpine head unit with plenty of RCA outs and alpine type s components or "splits" as some people call them in the front.
Im going to buy a 4 channel amp and another set of components/splits, obversely 6.5". Id like to just put the new speakers in the rear as the front tweeters are custom installed onto the small triangular piece on the front doors with fabric stretched over them, saying that the Type S's are only 50w RMS and the next lot will probably be a bit higher.
How would the new speakers go with the type S tweeters hooked up to them?
Also I have NO idea on what RMS to get when I buy and amp and what OHM ect ect?
Any help much appreciated,
chris
https://www.sau.com.au/forums/topic/337407-stagea-audio-speaker-and-amp-qs/
ull want to get a set of 2 ways or something like that for the rear... or a set like the mb quarts i had where the tweeter mounted on the woofer... so a 2 way/split setup i spose... as u wont want to have a tweeter in the rear floating around...
just but lukes shit n b done with it...
wiring kit, and 14v fuel pump setup while ur f**king with cables n stuff :D
I personally always match my front splits and rear 2ways from the same series.
That said I would replace your splits- Hertz on a budget(and no sound deadening), I also like the sound of MB Quartz. Some Soundstream gear is decent. Focals are a popular option.
I like audison amps, compact, quality. Mount under a seat. Rockford Fosgate amps are popular, I only liked their sub amps last time I checked, some soundstream amps are again decent!
Give Simon at MOB a call or check out their website for suitable audio gear. MOB have done most of the work to my stag and they're awesome. I have kevlar splits and amp package for front and rear and sound quality is tops. 10% discount for club members too.
Give Simon at MOB a call ......... 10% discount for club members too.
I'd love to support the locals but with the dollar the way it is stuff from the states is about a third of the price of retail here atm.
just do what im doing, dump the rear... ( i mean how much time do 'you' spend in the back..???) fork out for sme decent quality front splits, buy a decent quailty amp. (bigger the better).. why i say this is that you can always turn the gains down, but when there up full, you cant go any higher.
for example here is what im putting in mine....
http://www.hybridaudio.com.au/index.php//L...t-Set/p_28.html
these are getting power from 2x Alpine MRV-F540 amps the 8" will be getting 200w RMS and the mid and tweeter will be getting 80w RMS each.
also when installing new speakers always use new wiring, the factory stuff really wont hack i after a while.
ps here is what the back is going to look like.....
I found it noticeable when faded all to the front(simulating no rears) Stagea rear speakers are placed a lot closer to your head than in a skyline(parcel shelf) for example.
Can someone please reply to the ohm and wattage questions?
Looks like you'll be giving everyone on the road a goodheadache infiltrator :cool: why not just get one highend sub instead of four type s's ?
Most car speakers are 4ohm speakers, and most off the shelf amps are for 4ohm speakers. check out alpines website for some combo packages, even if you dont want alpine it will give you a good indication on what to buy. also, dont go with what people say.. go and take your fav cd into the stores, and listen on the demo boards.. .what sounds good to me, might sound crap to you.. and vice versa.
any more info might want to go to http://www.mobileelectronics.com.au just go to the search and you find all the info you need :)
as for the subs, trust me when i say the type s subs are great, the two that i have, (the ones in the pics) (i photodhopped the pic thats y there are 4) have lasted me almost 9 years and produced a 135.5 Db in my old bluebird wagon... so yes there cheap. but they are proven, to me anyway. also i dont want huge 15's so 4 12's are a comprimise.
Edited by infiltrator
type r all around
i've got focal splits up front and type r 2 ways in the rear doors, no sub (yet)
all running off the head unit (think you need the same Ω front and back)
you can notice the sound from the rears more than you think and it gives it much better "stage" if they are all matched
i find the focals lack a bit of mid and bass but the type r's do well
im thinking about one of those under seat subs too, or maybe a powerful 10" in a small ported box
or maybe i'll put the twin 12's in from my suby :)
In the old car i only had fronts, came 5 in aus, SQ comp 2005.
The rears are only for fill... i like my stage all up the front, but saying that. that is my preference, audio is a very subjective medium, for everyone is different.
for the HU powered speakers all have to be same ohms, but in an amp setup, you can have on a 4 ch amp, ch 1+2 @ 4ohm and ch 3+4 @ 2ohm. but the amp must be 2 Ohm stable. if you are using the rears @ 2ohm they will sound louder because there will be more power into them.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
