Hey, I'm looking for someone with an R32 GTS-T that might be able to help me with some questions. I have a set of front knuckles and hubs off of a 4-door R32 Skyline GTS-T. I have the suspension for to fit it but I can't figure out where the suspension hooks up to. I think I'm probably missing a the upper links. I'm just not sure exactly what the GTS-T set-up looks like. If anyone can help me out with pics or something that'd be cool. If you can help me out with any of this, let me know. Thanks.
https://www.sau.com.au/forums/topic/33752-for-anyone-with-an-r32-gts-t/
Hey, I went all over that site and couldn't find anything that gave me enough info. Found pictures of the actual suspension but not of the upper links, lower links...the knuckles...etc. do you have a gts-t? i was hoping to find someone with a gts-t who could take a picture for me or something. well, let me know. Thanks.
Hi Zushi this is the pricture of the front suspension on an R33 GTST from the Whiteline site. The only difference between it and R32 front suspension is the upper control arm. On the R33 it is a wishbone..
R33 GTST front suspension
The upper control arm on a R32 looks like this instead of a wishbone, This is an adjustable one, the standard item does not have the bolts and the slots, it is fixed in length.
R32 upper wisbone
This is a picture of R32 front suspension
Hope that helps some more
hey, thanks for the help. i can't really tell exactly what im missing though. the only pieces i have are the knuckles, hubs, and of course calipers. what im trying to do is convert my s13 silvia from 4 lug to 5 lug using the pieces i got off of a 4 door r32 skyline gts-t. the rear knuckles were a straight swap and pretty easy. the front though i need more pieces. just trying to figure out which pieces im missing. i know i need the upper link pieces that go from the knuckle to the suspension....right? will i need a lower link? if you can help me out with the info i need on this swap thatd be awesome. well, get back to me. Thanks.
Hi Zushi, why didn't you ask this in the first place?
An S13 has Machpherson struts, it is not double wishbone like a Skyline. (ie; they have no top arm). The shock absorber is the top arm on an S13.
To fit Skyline front brakes and hubs you remove the disc and rotor and the hub and fit it to the S13 strut. There is probably some trick with the wheels bearings. You don't use the Skyline upright at all.
If you need more info than that I suggest you try the Silvia forums they have more experience with what you are doing than a Skyline forum.
Hope you succeed.
No Zushi, all you use from the Skyline is the brake callipers, brake discs and hubs. All the rest of the Skyline bits won't fit a Silvia. You need the Silvia struts and lower control arm. There is no upper arm on Silvias.
The Silvia forum guys will have photos of Silvias with Skyline hubs, discs and callipers. Ask them.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
