Ahhh but who says I'm right? :D
well atleast you agreed...what i say is usually questionable...but nice to know that what i think and what i direct others are in the right direction... ;)
  • 10 months later...
  • Replies 73
Hey guys. I've never changed oil on a turbo or perfomance car ever.
Was wondering is it the same as any other normal car?
Would yo use an oil flush let it run then drain it all out? Or would that not be advisable? A bit worried as I'm running a ball bearing turbo? Would this pose any problems?
From memory:
Nissan recommend 7.5w-30 (in JAPAN) on new engines. Probably to help fuel consumption.
I'd go with 5w-40 (Shell Ultra or Fuchs or Motul if you can afford it)
NISMO recommend 10w-60 for track work.
The RB25DET is 12 years old, not rebuilt and ~150,000km old. The SR20DET is 13 years old, not rebuilt and ~90,000km old. Neither blow smoke. Both have excellent compression and make the power I'd be expecting from them.I just find the thinner oils break down far quicker and end up thin and watery by the next oil change. The slightly thicker oil gives me a quieter engine and I drain almost exactly what I put into them out at the next oil change. A good number of 10W40 oils contain a lot of friction modifiers to achieve the desired viscosity, they're not fantastic for the engine.
Yeah the oil seems thin when it comes out cause it is warm.
If it is much thinner then it is diluted with a LOT of fuel - doubtful.
I've tested viscosity of a few oils new and used from my car after 7500km and there is a bees dick in them. Used oils are slightly thinner - a few percent which was probably fuel.
FWIW viscosity at 99°C in Cst
crankcase oil SAE 20 >>>>> 5.7-9.6
crankcase oil SAE 30 >>>>> 9.6-12.9
crankcase oil SAE 40 >>>>> 12.9-16.8
crankcase oil SAE 50 >>>>> 16.8-22.7
Edited by simpletool
Fill til it comes out the filler plug...that's what it's there for. For obvious reasons you won't be able to put any more in!!!
laugh it up when i worked at ford an apprentice did just this!
fill it up you said aye
he filled it alright bout 25litres of oil i think in an xt falcon
:blink:
I'm surprised to hear so much variation here. My R33 GTR took 4 litres, mabe a bit over, but nowhere near 5L. Do they all have different sumps? Is there a benefit to overfilling it some?
what the.. my 34s rb25de only takes about 3.5L...
i use motul turbolight 10w40 btw
I'm using Royal Purple 10W40
Sorry about the multiple posts, I kept getting an error message.
Edited by Ishman
ive used 2 different oils now, motul 4100? turbolight 10 40 and before that used to use mobil 1 5-50
both only used 3.5L (not even close to 4)
does this include a filter change?? i always get just under 5 in and its on the full line of the dip stick. maybe 200ml left in the bottle. im slowly filling one bottle with all the left overs of other changes :nyaanyaa:
If you do oil filter change, drain the sump very well and pour 5L of new engine oil in. Make sure the engine is warm to allow gunk to all come out before draining.
  • 1 month later...
was just fine, but i havent seen any difference since using turbolight .. and its much cheaper
3.5 liters in an rb?
doing it wrong
by the book it's like 4.7l or something
just put 5 liters in, saves wasting it and isn't going to hurt your car at all. it will help stop oil starvation if you drive around the streets like a mad flamin mongrel
doing it wrong
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
