Group Buy: Gates Skyline Timing Belt Kits
G'day guys.
These are from Repco, have a mate that is Store Manager
GB: START 23/09/10 - ENDS 31/10/10
Here's all the info on them - make sure you read all of this cause it'll probably answer all your questions.
http://www.gates.com/australia/brochure.cf...cation_id=15486
To keep the price down, I need to order 10 Timing Kits
How to get onto this great deal"
You can do direct deposit into my account then I'll express post them to you once the GB Ends. Both ways are fully tracked so they won't go missing.
Express post & handeling cost an extra $15 nation wide.
You can choose between standard Gates Timing Belt Kit VKMA92504S
Or
VKMA92504SR Gates Blue Racing Timing Belt Kit
Cost Price VKMA92504S (Standard) RRP Range from $279 +
- Suit RB26DETT
- Compatible With R32/R33 & R34 GTR
- Exceptional Durability
- Wear Resistant Teeth
- Robust Reinforced Tooth Jacket
- Super Strong Tensile Cord
Kit Contents:
- Gates Timing Belt
- Genuine NSK Idler Bearing
- Genuine NSK Adjuster Bearing
- Camshaft Seals (2 Pcs)
- Crankshaft Seal (1 Pcs)
10 Timing Kits $229 + $15 postage & handeling
10-20 Timing Kits $219 + $15 postage & handeling
20+ Eiming Kits $209 + $15 postage & handeling
Option 2
Gates Racing Timing Belt Kit VKMA92504R RRP $395 +
- Suit RB26DETT
- 300% Stronger Than OEM Belts
- 3 Times More Head Resistance
- Perfect For High Horsepower Engines
Kit Contents:
- Gates Racing Silicon Timing Belt
10 Timing Kits $305 + $15 postage & handeling
10-20 Timing Kits $295 + $15 postage & handeling
20+ Timing Kits $285 + $15 postage & handeling
This gb will end in about a month or before if we can get the numbers.
Ordering: To order , just put a post up here or you can PM or send me an email at [email protected] with your details.
Feel free to ask me any questions.
So who wants to start the list.
Abit of Info Below:
Don’t Risk It, Fit the Best, Fit Gates
Gates Racing Timing Belts have been specifically designed for high output and high RPM performance tuning applications. It is constructed from high strength glass tensile cord to increase its performance and reliability, providing customers with a product that can be trusted under immense pressure.
Gates TCK’s with Racing Timing Belts provide a mechanic or performance enthusiast with a complete kits including a high performance timing belt, idler pulleys, tensioners and seals, to ensure your vehicle is equipped to perform
1) R33KID
2)
3)
4)
Edited by r33kid
What are you on about
A group buy is supposed to be about providing parts to the Skyline community to save them money.
I'm pretty sure Kudos (forum trader) sell these at the same or cheaper price. Fairly sure 999 sell them at that price individually as well and I only just raised my price on the racing kits to $300. Your friend at Repco is going to have to do much better than that. Unless you are trying to make a few dollars yourself....which is not really the purpose of the group buy idea
also Repco workers get items at cost.. So your 'mate' can get you one for the price he can.. Which is alot cheaper than that.. Unless he plans taking large amounts from you also..
i spoke to Daniel from WWW.ERD.COM.AU and he was great help.
Spoke to my mate at repco and he said that is the best he can do.
Daniel said if we can get 10 ppl he can do these for $260 for the racing kits, so if he's keen its best people just talk to him direct and he will orgainise.
Thanks
Edited by r33kid
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
