finally got my baby back on the rd...
its only been what? 2 months sitting in my driveway colecting dust.
feels so good to drive it again especially now with the GTR seats in it instead of those OBX seats which i had to dodge up the rails an inch higher to get in lol.
now to fix up a few things...
-steering wheel (need a tap big enough to recut it)
-wheel alignment (one wheels got too much camber on it as apposed to the other)
-new front tyres
-GTR guard liners cause it looks weird without em
-good servicing and a bloody good clean
https://www.sau.com.au/forums/topic/33861-finally-got-my-baby-back-on-the-rd/
nothing i just couldnt drive it cause i had no seats in it...
ive been waiting til i sold the OBX seats til i could get the GTR seats... which i sold last night.
its been sitting in your driveway for 2 months and its YOU you are waiting on? shame on you for neglectting the skyline!! I'm gonna report you to the RSPCS - No wonder you've been having crazy ideas about minis, beetles or god knows what else.
lol *** all yall...
i had other things to organise and waste money on... like the shit heap of a daewoo which some ***wit decided to use as a running ramp which just also happend to over heat and BOIL the oil to a thick chunky goo while someone was using it.
800 for the pair which was just a little more than what i brought the OBX seats (which didnt have rails)... which i sold to get these.
painted dash was meant to come out a very dark grey much like the rest of the trim in the car... which ended up coming up a very light bright grey which is why theyre being painted back to black gloss :D
thats not a bad price for a pair including seat rails. Where did you pick them up from or was it a private sale?
Good to hear your painting it back to black, for a minute there i was a bit worried you might be converting to rice mods :D
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
