  • Replies 49
lol - i'll happily 3v3 custom with you blokes to give some practice on maps/tactics :D
Forget ladder though, luck would have it we'd end up matching against mates of mine hhaha.
My mates are a bit unreliable at the moment though - its hard enough for us to even get each other online lol.
Maybe try organise for like a Tues next week or somethin?
WC3 solo/team was similar in some instances however SC2 team play is massively different from solo IMO as just a simple thing like map draw can have major impact.
Some maps have some ridiculously abusive strats that are so easy and so effective it makes you cry - nothing that can't be stopped/countered though ;)
cannon rush is where protos sneak into your base area out of site and start making their defence cannon things, and eventualy just take out ur base with them, very annoying
the good thing though about them is, they will focus on that the whole time and if u counter them, they will be way behind in the resource and progress part of the match
so easy to counter - same as a ling rush
simply make your barracks or gateway sooner
yea it is easy to counter, but you really goto push units asap to do so, which sometimes i dont...
if you scout, and workout how far the pool is done/how many workers you can gauge what they are doing
tis all about timing
    • No, so what happened is. I put a bunch of filler then I sanded it all down, I removed all the filler (unintentionally), then I put the epoxy primer on because that section of the panel is bare metal. The car is parked outside so I needed to protect it in the meantime incase it rains.
    • It’s definitely an import, the Aussie ones have reflectors in the rear bar, it’s also a turbo which none of the Aussie one were.    I remember back in the day I want a twin turbo z32 so bad and then I saw a 32 gtr and that was the end of that lol
    • Same can be said for Subarus motors ha ha!   I like the 300ZX, I nearly bought a Z32 before I bought my first Skyline. It was going to be a project. Then I found out there was a bit of a dodgy title with it... As in, someone attempted to commit insurance fraud with it and there was now some dodgy legalities around it. So at 18 I walked away from it.
    • The below is what the readings I had with the fuel pressure gauge which were correct. It seems like the issue is mainly during drive and not idle. I bought the new hanger hoping it could be the issue, perhaps I ruined something while cleaning, but I have not installed it yet since I have to wire up everything with the new plugs.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
