This isn't confirmed yet...but...
One of Japan's most reliable car magazines, Holiday Auto, is reporting
that Nissan CEO Carlos Ghosn will make a significant announcement
concerning the next generation GT-R at Nissan's Tokyo Show press briefing on Oct 22.
The car will not appear, but critical information will be revealed.
NEXT GT-R REVEALED
According to the report, Ghosn will outlay a launch schedule for the new GT-R supercar with an unveiling set for the September 2005 Frankfurt show. The car will then appear again at Tokyo and then at Detroit before Nissan reveals the final production version at Geneva in 2006. The report also confirms that the next GT-R will be powered by a specially developed 3.2 litre V6 with a new electrically-assisted twin turbo setup generating in excess of 480 hp (350kW) placing it directly in Porsche 911 turbo territory.
Sitting on an aluminium space frame, the GT-R will employ a steel cabin unit blending light-weight materials with high rigidity strength.
The hydraulic centre differential used in the the outgoing R-34 will be swapped for an all-new magnetic clutch configuration with a choice of 6-speed Getrag manual or an 8-speed CVT inherited and upgraded from the current V-35 Skyline GT-8.
A revised Atessa ETS 4WD system will also be incorporated while the GT-R will sit on 245/40R19 rubber. The new model will also employ 6-pot Brembos on the front and 2-pots on the rear. But while we can reveal these details today, the final styling of the GT-R has not yet been signed off, hence the absence of it from this year's Tokyo show. Nissan know they must keep price down, and several commentators including the Holiday Auto report suggest a price under 8 million yen.
https://www.sau.com.au/forums/topic/33869-8-speed-gtr-anyone-d/
Where do we sighn up?
thats a $10,000 deposit and $1750 per month (about the same as some insurance premiums) to own it outright (assuming a mid 2007 delivery).
Or
$10,000 deposit and $56.70 per day.
A small price to pay for a new 2007 GTR
I guess it would be slow over the quarter mile though, 8 gear changes would cost me 5 seconds in changes alown :-P
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
