to OP. cefiro genuine piping fits best. anything else will need slight modification. if you're doing de plus T..
Trust me from experience. Get an r34 smic. Don't sleep eat or piss until you get one. Don't waste time with a31 smic not worth it.
De+t setups run best with r34. It's big but small enough to retain boost response. And to all naysayers. It's plug and play with a31 piping.
Richard, get a core. ive got lots of s13/r32 piping we can make it work dude? if not we can weld them up????
cheers for the replies guys, ive found a cooler but havent bought it yet, if you've got piping and connectors, oooh yea i want them
can we do deals on sunday?
R32 pipes need to be cut down a bit.
I've got a Cefiro SMIC, brackets and pipes which I don't need if I go ahead with buying a halfcut (either tomorrow or Monday).
We can make a deeeaaal yeah ?
Dammit why do you have to be in Perth right now,
from memory R32 SMIC piping dont fit, I was chasing up the piping at one stae and thought to go R32 but the holes through the chassis were in a
O not a O configuration, the piping was quite different.
O O
You'll have a better chance with R33 piping so long as you have the turbo to cooler pipe for the 20 as the 20 turbo has a smaller outlet.
cheers for the info, I got a R32 one and pipes and they seemed to fit up ok, I didn't want a FMIC I will if I upgrade the hairdryer
the reason it would be a good idea (or most people do) get a larger intercooler is because the factory intercooler is very small and suffers from heat soak really bad (it's more like a interwarmer , theres nothing cool going through there after a 20 min drive , especially through summer) which is why people were suggesting to buy a fmic , even a small one :( . try his: get some vacuum line and re route the back window squirter line to the intercooler with a garden spray squirter at the end of it (aim it to spray over the core as much as possible) , next hot day after driving it wherever and getting it up to temp for a good 20 min , hit the sqirter button and see/feel the difference it makes :)
I know it makes a huge difference, I had a doozy on my old RB25 VL commohore, the fmic will find its way onto mine soon, I just needed the car back on the road, its a wonder the humble RB20det, I remember when they used to be the fastest thing ever 10 years back, not so much now, but its better than the DE it had, god im glad thats gone
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
