Going to get some braided lines made up as a few of mine are corroded and leaking..
Having removed the turbos last night i have a question in regards to the lengths. The water (return i think?) from the split on the block for the rear turbo does a loop before the banjo joint on the turbo and the oil supply for the front turbo does the same.
I assume this is so the pipes are equal lengths due to the different locations the splits are on the block. So on to my question..
Should i get the braided lines made up to the exact same lengths as the standard piping (including the loops) or can i get them made up shorter - not sure if this will effect supply/return to the turbos and possibly cause premature wear?
Anyone who could shed some light would be helpful :(
https://www.sau.com.au/forums/topic/338825-rb26-braided-turbo-lines/
Anyone who could shed some light would be helpful :)
Hey,
I think those loops are to allow movement as the manifolds expand/contract (the pipes are quite stiff).
I replaced mine with braided lines (no looping) when I went to a big single; no problems thus far.
Cheers,
Saliya
I'd urge you to use stock replacment steel lines, not braided. Especially if it's a street car. The braided hose will perish relativly quickly witht he constant heat cycling.
But hey, braided hoses look pretty I guess...
J.
well...... oil cooler lines dont run near the exhaust manifold, turbo lines do
just use that orange stuff with the fibreglass inside it, works wonders for high temp sheilding
they come in different sizes to suit braided turbo lines, breather hosing, wiring looms etc
ive used that stuff on breather hoses that are actually touching exhaust piping, its been about a year and its no where close to burning through
pic:
edit: sorry i just realised your still running your twin setup and i also urge you to run the standard metal lines for more reasons than 1
just make sure you use fresh copper washers, the lines have no kinks or have ever been bent
what i wrote above applys to topmounts but i guess you could put some sheilding on the steel lines too? haha
Edited by snozzle
Oil cooler kits all use braided lines, never thought a braided hose would perish any quicker?
I am more wanting to do this for ease of installation - obviously looks aren't important as you can't see down there once the piping is on!
As was said above, oil cooler lines are not exposed to the same heat/thermal cycling as lines in/on/around exhaust manifolds, dump pipes, exhaust housings etc.
How often do are you planning to remove/install the turbo's???
Measuring and making the hoses will take you hours to do properly... Not to mention the cost.
Also, that orange sheithing is designed as a flame barrier... it's designed to stop a direct flame from penitrating it for a pre-determined amount of time. It dose work to insulate against some heat though.
Cheers
Justin
I used the orange stuff to shield a teflon braided oil feed that ran very close to the exhaust manifold (<5mm clearance) and on the turbo drain covering blue rubber hose. After less than 1000k's I've pulled it all apart and the shielding on the drain looks fine however the hose underneath is charred while the orange stuff has dried out and crumbled on the oil feed with the teflon line also blackened. Don't assume this stuff does anything! Hardline and a good air gap are the way to go.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
