Hi guys,
I was driving around for a fair while with a few leaks within the gasket and power steering hose. So this week i got everything fixed up mechanically. Whilst they were checking out the car they noticed my fuel tank was leaking and the seal had somehow moved to within my tank. So petrol was leaking from my car (Which explained my complaints about fuel usage). Anyway they had repaired everything and i finally got it back yesterday. I noticed whilst i was driving when i went to accelearate in a higher gear it would hold back and jolt slowly into acceleration. It was like there wasnt enough fuel being released and a leakage had occured. I also droved it last nite and noticed it had gone worse. I brought it back there this morning and the mechanic was a nice guy and took it for a drive. He was speeding most the way and hadnt noticed any jolting. Now when i drive it i slightly notice this jolt but only in higher gears (3 & 4). He had said it may be a missifing problem and my spark plugs may be old/not close enough. But i was driving around with these new spark plugs (2 months old) without any problems. Do you guys reckon theres more behind it and may be a fuel problem? or may i need to get new coil packs or tape my standard ones up?
Thankyou
https://www.sau.com.au/forums/topic/338953-boostingaccelerating-problem/
What gap are you spark plugs at and how much boost are you running?
It could also be your coilpacks breaking down. Taping them COULD work for awhile but due to the heat the tape would get brittle and eventually break apart - and you wouldnt want that falling into the spark plug chamber as you remove them out next time!
I'm using NGK Iridium BPR5EIX.
Which I'm pretty sure is a 1.1mm gap. But what i dont get is that it shouldnt change what the engine was previously doing? all that was done was a rocket cover gasket change?
My guess is th at it is the coil packs that are the problem. Do you guys recommend the industry grade silicon in fixing the problem? So that it doesn't pollute and go everywhere.
cheers for the help guys
Try gapping your plugs like krishy said. Also with your coilpacks I coated them in high temp silicon which did the trick. If your spark plugs are gaped to 1.1mm then when your on high boost it will blow the spark out. Like blowing out a candle. Gapping them to 0.8mm will stop the spark from blowing out
fouled plugs could occur with a whole lot of other factors
hey its matt the 1 who checked your car on saturday and like i said u had alot of loose intercooler piping hose clamps and the pipes were close 2 coming out. so once i tightened them again there is a chance that there were leaks there but not anymore so the spark plugs could have been fould previously. so now it could b running how it should be and wanting to produce more power but cant due to fould plugs or faulty coilpacks.
anyway this is a mates account but let me know how u go if u do change plugs or coils.
Cheers guys
i'm gonna open it up tomorrow and have a look at it inside.
See what the hells making it missfire.
Cheers Matt ill let you know how it goes and thanks for the fix up's i appreciate it all..
I will firstly try out the spark plugs and then silicon up the coil packs should fix it :D
if it doesnt i will clean out the AFM & pod and see how that runs
if all fails does anyone have any other possible problems that may be causing it?
also make sure that all your cooler piping is tight as well....
if your AFM gets dry solder joints in it your ECU will go into limp mode
i have had mine fail twice now, first time intermittently it would cough and splutter as i would be driving and it would sort of fix it self, the 2nd time it wouldn't drive at all past 2500rpm
coil packs will normally be more top end, i would be going with intercooler piping as i have had all of the above happen to me lol, i replaced my fuel pump and all to find one elbow had a small split in it which made the car surge on acceleration
has the happen to me to steve then i has a full intecooler blow out went down port wakefield rd for 20 mins with hell black smoke to get home was a bad day lol, got home and the back of my car was totally black
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
