http://www.nengun.com/auction/item/v163900055
Pretty much want my interior to look like the above how does it work etc ?
say if i was to buy it do they just get thrown over or ?
Also i have abs bags behind my drivers and passengers seat i had a hard time throwing over seat covers as they just don't fit :\
theyre fitted throw overs, not universal throw overs, so they work a bit better, but you would need the same seats etc as the ones they are suited for.
ebay sells fitted leather throw overs to suite different cars, give them a look
hey mate,
You can try proseat http://www.proseat.com.au/testing/Nissan_R33_GTST_1.html they are based in Victoria. :thanks: came across them on ebay. They do front two seats and back seat for 570$ and free door trims and gearbox surroundings. That's what they quoted me on a r33 :D. Let me know if you get them done.. post some picture :thumbsup:
they look good from the pics, but i just got this feeling that they might be loose and similar to a universal seat cover :whistling:
id like to get some feedback from someone who actually has them
I went for ultimate auto trim in my R33 GTST. http://www.ultimateautotrim.com/
professional service. and the product has been great (been in over a year now, no problems).
I paid $900 (delivered to WA) for the full car option. front and rear seats, black and ivory colour combination, gear boot, handbrake, centre console cover, door panels, and rear speaker panel.
For the seats its essentially a perfectly fitted cover (matched to the R33 seat) that you then stitch onto the seat (easy job, just pulling about 8-12 cords through the seat to secure the cover)
Edited by jjman
wait... you stitch them to the seats?
wouldnt that wreck the original seats?
Seen jjman's Interior and it looks Awesome.
+1
Edited by SL33K
+1 for ultimate auto trim
i got full set for my 32
they have auctions on ebay starting at 99c occasionally
i got a full set with rear parcel shelf, door trims and centre console lid for $500
http://cgi.ebay.com.au/SEAT-COVER-NISSAN-S...=item4cf2c18de2
thats one thats up to 150
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
    • Ha ha ha, so they stopped the bearings spinning on the one you want, but then decided the crank hub should slip instead 😛   Stick to RB, at least you can work on it yourself. And now it doesn't smell of vapour   Also I still believe there's a chance your new flap doesn't "pop", as even though the engine might breath hard, it has a direct path with no restriction to the inlet, which when on boost should pull a bit of suction for you. If you do get pressure in the catch can id be very intrigued. Time to put a boost gauge on it, and a session at the track, then solid cover your vent and do another session
