Well, it's been a battle - and a learning experience, but it looks like my car will arrive tonight!
After waiting near enough to seven months, running into problems with DOTARS, cleaning and trucking it appears the process has been somewhat of a success... What lays ahead? a few compliance mods, over the pits, rego and hello blacktop.
Would I go through it again???? Thats a tough question to answer, I'm yet to see the car, but from all reports - it's good, but thinking of all the 'testing periods' I've had to endure, I'd almost have to say no.... but then again.... enthuasim is a hard thing to supress.
If anyone wants to know more about the whloe process, let me know. I look forward to seeing you all on the street, I'll post pics soon (Silver R32 with black and red rims)
https://www.sau.com.au/forums/topic/33967-89-model-import/
congrats DAN00H!....can fully understand how excited you must be...i remember when mine arrived (came from Brissy on a Finemores truck)..it was late on a friday and i had to look at it thru a fence till Monday morning when they opened grrrr
i was in a hypo mood all weekend till i could get my hands on it!! :)
https://www.sau.com.au/forums/topic/33967-89-model-import/#findComment-682017
Thanks Shell, it's great to finally have the car - it's in much better condition than I expected too!!!
I should have it on the road in a week or two (depending on what the inspectors at Dickson say!!). I've got a few jobs to do, namely raise the suspension (front lip is only 60 - 70mm off the ground and fit a cat.
Looking forward to catching up with everyone.
https://www.sau.com.au/forums/topic/33967-89-model-import/#findComment-683550
Hey dude are you sure thats all you have to do?? I got mine on tuesday, went up and got it, I managed to get mine cleaned on the day. hehe had a good look at yours too I might add! its nice good buy, I trailered mine my self.. I am pretty sure you will need to get side intrusion bars?
https://www.sau.com.au/forums/topic/33967-89-model-import/#findComment-684769
Hi Stirlo
I spoke to the head inspector in Dickson that runs the show (have name and details somewhere) he said intrusion bars not needed if rego in ACT, DOES need child restraint points fitted in the rear and must pass a roadworthy inspection (tyres, oils leaks, ride height, noise level, Cat, tint, brake test, rust etc...) I had to do the same when I got a car from QLD.
What is your car then? I had Milan bring mine down on Tuesday night - he does a lot of them and really liked mine... Know anyone that wants to buy a rollcage?? I took mine out.
https://www.sau.com.au/forums/topic/33967-89-model-import/#findComment-684781
might be interested in rollcage for right price in a 2months or so if you can wait i can buy!! well done id like to chat with you about the whole 15 years thing one nite my bro is interested so youll have to met up with a few of the boys one nite!!
https://www.sau.com.au/forums/topic/33967-89-model-import/#findComment-688771
no worries - happy to chat about the 15 yr process to anyone, I'll be running around on Friday getting my car ready for rego, so if anyone sees a silver 32 R with black and red rims - that's me!
Just a note to anyone else who might be going to rego an 89' in the ACT - check it out with the dickson rego office before you pay $500 - $1500 to get it "complied"... you may not need to spend that much!
have the cage sitting at home - haven't thought about a price (I have no idea what they arte worth!) anyone have any ideas? I might reassemble it and post a pic.
https://www.sau.com.au/forums/topic/33967-89-model-import/#findComment-689056
Danooh - I got mine transported using Canberra Carways, they charged me $275 to get it transported from their Sydney depot in Moorebank to Mitchell.
How much did you have to pay Milan and where do they pickup from and deliver to?
he took my car from the wharf to Hobbs (what a rort) cleaners, then from Hobbs to my house.
$620 - which I was happy with as i didn't want the trouble of going to Sydney and taking a day off work etc. he picked up my paperwork and organised to get it up the line to be cleaned and brought it down that night!
https://www.sau.com.au/forums/topic/33967-89-model-import/#findComment-690358
Hey Danooh, I have checked with my engineer, and was told you need intrustion bars, I will be very happy if you dont, can you varify that you dont need them? how close are you to getting it registered and who is doing your cert? I would mind seeinh your car some time too :D
https://www.sau.com.au/forums/topic/33967-89-model-import/#findComment-690867
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
