Your commitment is unbelievable but why a gtst?. With all due respect wouldn't a rough 32r as a base have been more worth the sweat and cussing that a project like this involves? A rough 32r starter like this would have been fairly well priced? Please don't take the wrong way I just don't see the logic. Regardless thumbs up for a thorough build.
I'm digging the audio selection-
Stock looking- but hiding some nice gear.
yep! and if I decide to do anything decent in there that deck will still stay there. in all honesty that deck will do fine for what I want. hell my van has the stock radio in it and I have no intention of changing it.
Nice brake selection, i am also looking at those for my 32 build
ta! blame 'roy' for it.
ive got a burgandy gtr bootlid + spoiler, want to swap for your black one :P /too bad not in Vic!
Ive heard rumours that the gtr bootlid doesnt sit flush on GTST? Can you confirm. How is the fitment?
fits fine on the left side and flush on hte rear edge. can't comment on the right side for obvoius reasons.
no offence taken :) I am doing this car simply because I didnt want a GTR. but if you look at it from a money POV I'm not out to make a profit on this car. I have had plenty of customers cars over the years that have spent $15-20K on the engine alone. I haven't. build for this car will probably be $15-19k overall. most of the 32's I see have been bent in some way and that includes the GTRs. a decent GTR roller still goes for silly money and I still have the rust issue to deal with in rear of the car. one of the toowoomba guys bought a runner for $25k + and still had to fix the rear of the car. in my case I will know that there is no rust in the car at all.
I build cars because I enjoy it basically :)
Oh I got a set of quater glass trims off Nissan at the end of last week. Got mine for $135 a side but that was my bosses buying price seeing as he buys well over 30k worth of parts off them each year
price for qtr glass - I show it as a full assembly so glass/rubber trim and 8mm bolt. are we talking the same piece?
Don't think so. I am talking about the inner trims around the quarter glass that peels
nah already got those. roughly the same price locally in brissy. I am like your boss . I spend a fair bit with metro at windsor. I thought you were talking about the glass. those are $600 or so each..
new boot panel sitting in place - easier to store it on the car that way it does not get bent.
putting it back in also allows me to store the tail lights again.
another shot . looks ok from the back with the GTR stuff in place.
new roof panel. this has been test fitted already. fits perfectly where I cut the other one off. I'll keep it stored in the box as it was NOT cheap.
roof part number - sunroof version
front bumper. GTR version. I had this stored for a while. decided to take a shot of it whilst I was taking other photos. it also stays in the box.
part number for those playing at home.
rust removal - phosphate converter used here to reseal the area. it still needs a cleanup
this is part of a repair job on the drivers side. a fair bit of this area has crap in it. all the sanded area has been rust treated and resealed. the lower sill area I cleaned out so I could find the seams. (this will make sense later when I remove the sills.)
rust removal - phosphate converter used here to reseal the area. it still needs a cleanup and a 2nd/3rd hit.
test fit of the roof. perfect. I need to trim a bit more away on the corners. when I cut the old one off I left 10 mm of error there. the original factory seams line up perfectly. that means the roof will drop into place one the trim is done on the body.
there are a couple of areas on the left side drip rail that I was too enthusiastic with and they will need to be re molded into place. the roof panel was lightly bent onthe right rear corner and left front corner. I would call it shipping damage myself. given it was a ex japan piece I'm not overly worried.
a BIG thanks to DUH19 for letting me take 'useless' photos of his car. (white GTR)
I was having issues with the rear inner fuel tank bracket location and the actual bracket shape (FAST listed two different ones.) but it turns out that the bracket IS the same as the one I have here and it simply slides to the left one hole. his car helped me work that out :)
about to do a compression test on the engine - hopefully 150PSI + across all 6.
No problem champion - thanks for fixing the light issue!
ok just found (via a contra deal) GTR fuel tank with straps,GTR BOV setup, turbo inlet/return piping , rear wiper motor with decent threads (mine works but I trashed the threads getting it off.) and a host of other bits and pieces. now to remove it all off this wreck.
pete,
working on it..
did a bit of quick fiddling before I left the shop tonight: the BOV setup all lines up. no holes in a few spots BUT the punch marks are there in the new panels and its a case if drilling them out.
I will spend tomorrow (after I get a car done/out of the shop) pulling all of the wreck apart and looking over things. the subframes are still there and the front one is straight. not sure if thats up for grabs or not.
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
