certainly did - NEW ones. 4 figure sum for both but yes I can certainly buy them.
need to pin you down at some point to discuss this car of yours and the parts needed for it.
chris, i love you and this thread <3
plenty of stuff available for the car. it just takes time (and lately a lot of money :( ) keep watching. once I get a bit of money ahead I am going to do the interior.
had a bit of spare time today so I started on the Nismo 32 dash (v2)
V1 that I paid money for
the start of V2.
that is a 3mm piece of acrylic cut into the stock hole. keep watching.
quick hit with a dremel to get the basic shape. the hole was marked with the steel overlay that was on the LCD panel I am using. there is a small amount of error there so its not visible in the final version.
back shot
now with qbond holding it in place. it doesn't move. I actually broke it in the top corner (speedo side) so there is qbond on that at well.
back shot.
just add bog. this is actually a finishing bog so its fine and quite easy to sand off.
first sand - this is hit with 400 wet/dry. light is horrible but it doesnt look that bad.
Once this is highfilled , 45 deg chamfer on the gauge holes ( they are stepped at the moment.)and painted black it will look like it belongs there. I called it a day at that point. will do some more on it when I get more time.
nah. all of it is external to the cluster. I am considering mimicing the odo reset button as a mode switch for the navi input. currently its on one of the radio buttons on top of the dash. there is a custom module for that.
hope to have this on a skewer in a few weeks so I can do a few more things to it and get it ready for panel work. lack of a proper shed for the last few months has hindered progress.
still working on it though. nismo 32 cluster is done.
  • 3 weeks later...
yep it should. will be spending a bit more time in gympie now working on it. july should see more images of it being torn down and packed into boxes again.
  • 4 weeks later...
harnesses - one sorted. still need to do the engine harness and put it back it std spec.
car is also fully stripped and on skewers - I am giving it a VERY good thinners bath.
  • 3 weeks later...
ordered a few small parts for it yesterday. mainly inside trim stuff.
door panels (GTR) are approx $450 each. once the small trim stuff arrived I am going to order one panel.
I dunno if you get good prices at your local Nissan but have you tried getting parts from Nissan Japan?
With all the parts your buying you might be able to save a heap over time.
Well done tho.
only things I buy local are glass and BIG panels. the rest is done out of japan. (okinawa actually) . I buy a fair bit off them and get decent prices because of it.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
