wrecking Nissan skyline r33 gtst 1994 with front damage need radiator support
lots of parts available just ask cheers
motor rb25 det complete $2000 ( low kms 93,000)
gearbox $1300 ( low kms 93,000)
pedal kit $200
tail shaft $200
flywheel $80
diff lsd $300
cv joints $50 each
stock springs & shocks $250
cannon with hi flow cat $350
stock exhaust $350
brake master cylinder $100
front calipers $300
front disks $70
rear calipers $150
rear disks $50
front hubs $100
rear hubs $200
handbrake cable kit $200
upper control arms each $30
lower control arms each $50
cross member $100
rear upper control arms each $25
rear lower control arms each $40
power steering rack $150
p/s bottle $20
rear sway bar $15
front sway bar $15
Hicas $40
heater core $120
stock wheels $300
300sx stock wheels $380 brand new tread nearly
stock computer $150 (man)
speedometer $150
headlight R $120
taillights $50 each
skyline tail light piece $50
power window reg $70 each
ignition barrel plus door locks $150
blinkers switch on dash $50
ac display $30
rear bar $60
rear bar reinforcement $30
rear pods $60
boot $70
boot shocks $20
doors $70 each
guard R $70
left quarter panel $200
rear cut $400 ( bare)
beaver panel $100
grille $50
fuel flap $10
fuel cap $10
skyline mats set $120
carpet $20
battery holder $20
washer bottle $20
radiator overflow $20
glass from $20
fuel tank $30
fuel pump $80
fuel lines $1 rear trims $15 each
door trims $50 each (bare)
rear trims $40 each
boot trims $40
interior light $20
seat belts (all 5 ) $150
dash (you take it out) $50
dash vent and surround $30
seats (front & back) $200 a1 condition
steering wheel $100 a1 condition
antenna $50
call me on 0415054272 car is in Liverpool area
can post anything you want as well
  • Replies 43
pedal kit $200
tail shaft $200
flywheel $80
diff lsd $300
cv joints $50 each
stock exhaust $350
front calipers $300
front disks $70
rear calipers $150
rear disks $50
front hubs $100
rear hubs $200
cross member $100
p/s bottle $20
rear sway bar $15
front sway bar $15
Hicas $40
heater core $120
stock wheels $300
speedometer $150
headlight R $120
taillights $50 each
power window reg $70 each DRIVERS SIDE SOLD
ac display $30
rear bar $60
rear pods $60
boot $70
boot shocks $20
doors $70 each
guard R $70
beaver panel $100
grille $50
fuel flap $10
fuel cap $10
carpet $20
battery holder $20
washer bottle $20
glass from $20
fuel tank $30
fuel pump $80
door trims $50 each (bare) ( DRIVER SIDE SOLD)
rear trims $40 each
boot trims $40
interior light $20
antenna $50
pedal kit $200
tail shaft $200
flywheel $80
diff lsd $300
cv joints $50 each
stock exhaust $350
front calipers $300
front disks $70
rear calipers $150
rear disks $50
front hubs $100
rear hubs $200
cross member $100
p/s bottle $20
rear sway bar $15
front sway bar $15
Hicas $40
heater core $120
stock wheels $300
speedometer $150
headlight R $120
taillights $50 each
ac display $30
rear bar $60
rear pods $60
boot $70
boot shocks $20
doors $70 each
guard R $70
beaver panel $100
grille $50
fuel flap $10
fuel cap $10
carpet $20
battery holder $20
washer bottle $20
glass from $20
fuel tank $30
fuel pump $80
door trims $50 each (bare) (RIGHT HAND SOLD)
rear trims $40 each
boot trims $40
interior light $20
antenna $50
pedal kit $200
tail shaft $200
flywheel $80
diff lsd $300
cv joints $50 each
stock exhaust $350
front calipers $300
front disks $70
rear calipers $150
rear disks $50
front hubs $100
rear hubs $200
cross member $100
p/s bottle $20
rear sway bar $15
front sway bar $15
Hicas $40
heater core $120
stock wheels $300
speedometer $150
headlight R $120
taillights $50 each
ac display $30
rear bar $60
rear pods $60 (SOLD)
boot $70
boot shocks $20
doors $70 each
guard R $70
beaver panel $100
grille $50
fuel flap $10
fuel cap $10
carpet $20
battery holder $20
washer bottle $20
glass from $20
fuel tank $30
fuel pump $80
fuel lines $1 (SOLD)
rear trims $15 each
door trims $50 each (bare) R/H (SOLD)
rear trims $40 each
boot trims $40
interior light $20
seats (front & back) $200 a1 condition DRIVER SEAT (SOLD)
antenna $50
pedal kit $200
tail shaft $200
flywheel $80
diff lsd $300
cv joints $50 each
stock exhaust $350
front calipers $300
front disks $70
rear calipers $150
rear disks $50
front hubs $100
rear hubs $200
cross member $100
p/s bottle $20
rear sway bar $15
front sway bar $15
Hicas $40
heater core $120
stock wheels $300
speedometer $150 (SOLD)
headlight R $120
taillights $50 each
ac display $30
rear bar $60
rear pods $60
boot $70
boot shocks $20
doors $70 each
guard R $70
beaver panel $100
grille $50
fuel flap $10
fuel cap $10
carpet $20
battery holder $20
washer bottle $20
glass from $20
fuel tank $30
fuel pump $80
rear trims $40 each
boot trims $40
interior light $20
antenna $50
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
