  • Replies 117
Can't be bothered giving mine a wash, haven't been washing the line as much as I used to, ever since I "modified" the front bar on that piece of kerb. Its too damn hot anyway. Looks like its going to be a good gathering.
haha... its just that another certain car occupying your mind now :)
And a big thanks to everyone who made the effort to show up!
At least 22 Skylines at the first meeting point! What a turn out!
About 10 or so at the top of the mountain... :) The rest of you were doing circles at the bottom or taking wrong turns :P
Thanks James for backtracking and collecting the NOOBS!!!
Good turnout at Yatala too...
Once again thanks everybody... Was great to put some faces to the names!!!
See ya at the next one... Who's organising? :rofl:
Yep great turn out
Good to meet a few more people and put faces to names.
Wondered why so few made it to the top, now I know, it is because the //GC crew are too fast heheh.
Big Prop's to Adrian for getting everyone together.
and i was trying to push away a fordmobile who blocked me on tha way up which made me loose you all :P ended up going around the mountain and into Logan village, took the toll free rd too GC and then back to coomera which was dead, met the rest at yatala but most left home already :hellpisd: a few of us cruised to milton maccus which we saw at list another 6 or more skylines driving in.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
