  • Replies 165
These people have sent me entries with nothing in the licence section:
Ash Cosgriff
Please print off the form from the link below, fill it out 100% and ... bring it to sign in with exact money
That is what I am doing. I have a form here and will bring with exact money on the day.
Most of the other guys in the list are FA's, and will be doing the same.
Crap, gosh, etc, sure is filling quickly, payed just now will fax entry in the morning.
woo hoo, FWD come on down, 109kw atfw with new ECU, long wang look out here I come. :)
Daniel Robson
Steven Skrekovski
Tony Skrekovski
Jack Kuzior
Ash Cosgriff
David Lee
Edwina Andrews
David Church
Srete Cvetkoski
Glynn Matthews
Please print off the form from the link below, fill it out 100% and either send it to AASA bring it to sign in with exact money please.
Anybody who does not have a licence can do this.
Ok just clearing a few things up. I'm not actually the one racing. It is my car but on the form I put down "Megan Vansteensel" as the driver. The reason my licence number is not on there is because it's expired and I wont be there to renew it. Megan will be the one driving the car and she will be purchasing her membership and licence on the day. Is that all cool? :)
WTF is with this 'cheater car' bullshit, im reading it everywhere lately.
Aint jealousy a bitch.
yeah sucks, FWD may be an enormous advantage but wtf fwd is ftw imo. jk
Yay! Clive representing the FWD's again :(
Not a problem, i did not see that. Ill change the name over.
Deca is well and truely sold out at this stage. list will be updated shortly.
Will fax forms tomoz morning for reserves list (however long the list will be). Was 50/50 about this round so I'll let the fate of other vehicles falling to pieces decide it muhaha.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
