Hey Kurt, don't you have a spare r31 auto box??? Your best bet would be to send the spare auto box away to get built up (more clutchs, bigger bands, shift kit etc) to handle the extra power... That way it will swap straight in without any buggering around... to put a 33gts-t auto in would be alot of stuffing around.. and it won't last as long as a properly build box anyway.
Cheers
Justin
I do have a spare one. Have no idea on what condition its in, not that that matters if i build it. Whats the cost in getting one rebuilt tough? The reason for wanting a 33 auto is because there dirt cheap, and should handle what i've got for the time being. Money is gonna be a little tight for a bit, and from what i know its fairly easy to put in the 33 auto. In the long run i'll get an auto rebuilt, but for the time being i want something that can handle the power i've got. Also have heard that the 33 box launches and changes gears alot better then i 31 box. Which i can understand when its 10 years newer.
  • Replies 206
My VL turbo was around 1100 to get built up fairly well... but that was 8 years ago. Unless the 33 box slides right in, then the cost for the conversion might be 300-800 bucks depending on wiring... I doubt that the box will handle the torque though- dunno, ask marty.
Definately use redline auto trans oil whatever you do.
Turn the boost down, save some money and build a box... The cost of a box will be about the cost of a good clutch!
Cheers
Justin
Cheers
Justin
I'll talk to Martin and see what he thinks would be best. Even if i can get an R33 Auto in there for the time being and then get that built later down the track, surely a built 33 box will be better then a bulit 31 box.
Dunno. We shall see.
Cheers
  • 4 months later...
just found you on there and the links in your sig on that site dont work either and i went back through your posts to may 9th and it dosnt show any posts from you in that thread alf!
Has it been deleted or in a section you need to be a special member to access?
Not much has changed really. I did put S13 coilovers in the rear and we also found an exhuast blockage that had been there from day one. So throttle responce is a bit sharper and she spools up a bit sooner. Also fuel economy increased a fair bit too. It really needs a new transmission and a retune though. It's current tune is holding it back so much.
Should have it in the body shop to get the entire front end tidied up depending on how tax time goes. And then later this year i'll have martin putting my new gearbox in it followed by a tune. Other then a few mild hiccups we seem to have ironed out all the creases and its running really reliably.
Alrighty, thought it was about time i put up some stuff about my car. I will update this post as time goes on. And i will add pictures as soon as i get around to trying.
Firstly my car is a Blue 1986 GXE Sedan. I got the car off a family friend as a car to loan when i first arrived in Tas so i had something to get around in and to/from uni. It didn't take long for me to get attached to the car and after some browsing through these forums i soon decided i had to make it mine. I asked if i could buy the car and sure enough it was mine in no time.
Here it is:
In the early days the beast was a bit tired and and the first thing i did when i started driving it was running in on BP Ultimate (now running on Vortex 98). This made a noticable difference. Only a few other things were replaced/installed over the next few months including things like a Bosch AFM and a few other minor things i can't think of.
Early last year, around may, my car was stolen by two 16yo's and a 13yo where they took it for about a 15km thrash, which ended when they blew the exhaust off! At the time they stole the car it was still running like a pig and i hadn't really spent any money on it. The little pricks were caught later on that day in a Subaru Liberty after stealing about 4 cars. (The 16yo driving was pursued by police in december after another string of car thefts and was run over by the police, which resulted in 2 broken legs. I was quite happy to hear that.)
I took the car around to the mechanic who i had been talking to for quiet some time and we had a full custom exhaust (Stock extractors) an oil cooler for the auto transmision and a few other minor things that i can't recall.
After some TLC the car ran better then she had before but as always these things never really last and soon i had a failing fuel pump so that was replaced with a Bosch 040. The next thing to cause trouble was the crank angle sensor which was replaced and made the car run like never before.
Now, onto the more serious stuff, i had finally got some money together to start some performance work on my car. I first purchased a new motor off a bloke who had it partially rebuilt with forged parts and had the valves polished. It also has a 292degree cam in the sucker. Along with the engine i purchased a Garret GT3082 with the housing brought out a bit. I dropped the car in to get the engine installed along with the sts turbo setup. Now for my turbo setup we have it mounted where the muffler normally would be with a straight tail pipe coming out of the turbo, it's got an external Sard wastegate and a lot of pipework up to the inlet. At the moment i don't have an intercooler yet but it seams to be doing fine, i can take it out and thrash it, hop out while she's still running and hold onto the intake directly above the engine with out burning my hands off.
Along with the engine i got bigger injectors, Nistune, a stall convertor and i've drawn a mental blank. Will update this when i get home.
The results,
Stock: 66rwkw and 193Nm Torque.
Modifided: 163rwkw, 434Nm Torque on about .8Bar
At this point i'll mention that we were making 175rwkw on the dyno with a few more pounds of boost to go, but the auto was slipping so we tuned it back to 165rwkw for the time being so the box doesn't shit it self too soon.
When i get home i will update this and include install pics and dyno results along with a more detailed list of mods to date.
Home now:
Will get back to ya's soon.
Cheers
Kurt
Here's a link to the thread in SAU: http://www.skylinesaustralia.com/forums/topic/340173-sts-turbo-setup/
And here's some dyno results, before and after. Just keep in mind the auto is rooted!
Got another picture here for ya's.
Just a picture of the setup sitting in the boot.
Wasn't completely put together though but gives you an idea.
Been a bit slack, i don't think much has changed on the car.
Bought some rims yesterday, 17X7, unsure on the offset. Here they are:
Unsure if i'm going to put them on or not. Will see what they look like, if they stand out to much i might not bother. Bought them cheap (The four rims with tyres in the pic plus 4 hald decent tyres for $150).
If i decide i don't want them my brother in law wants them for his s13 so we shall wait and see.
Haven't got a picture of the boot spoiler yet, but will do this arvo hopefully. It has a nice crack along it but i'll get that fixed eventually.
Now for those of you who don't already know, early march i had some scum smash my windscreen and scratch the bonnet. Was due for a new windscreen any way, so i'm not really out of pocket. Plus when they get charged (we know who they are) my insurance will refund my my excess. Here's a picture for ya's:
Any who, within the month she'll be fixed (already replaced the windscreen). I'm getting some more work done at the same time. The whole bonnet will be fixed (a few stone chips) and resprayed along with the two gaurds fixed up, resprayed and the inner lips rolled a little for when i get rota rims. Also the lip along the top of the bumper done along with my brand new standard front bumper installed and resprayed. Will also be getting the rest of the car cut and polished to make matching the paint easier and to make her look a bit nicer. So pretty much everything infront of the doors will look as new. Unfortunatly thats all i could afford at the moment. I will get before and after pictures for ya's of course.
Need some input though. Should i have the little silver badge (the one that says ultra) on the front of the bonnet removed and smoothed over or keep it? I think i want to keep it. unsure. Also, do i need the plastic on the inside of the gaurds? If not i'll rip them out when i get home cause i'm healthy of them rubbing (front suspension need replacing) plus they'll need to be cut when they roll the gaurds i assume. Ah and one last thing, is there any need got the sound deadning under the bonnet? Or should i turf that too.
Cheer fulla's.
Will get some pics of the boot for ya's soon.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
