  • 5 weeks later...
  • 4 weeks later...
  • 4 months later...
  • 2 months later...
still have:
-rb26 standard pistons(5 out of 6 good)
-rb26 standard rods
-rb26 fuel rail
- rb26 cams
-rb26 ecu
-rb26 coil packs
-rb26 ignitor box
-greddy new magnetic sump plug
-gates timing belt used for less than 1000k's before engine detonated
-standard intake pipework(twin turbo pipe etc)
-rb26 standard dump pipe X1
  • 4 weeks later...
Update
still have:
-rb26 standard rods
-rb26 fuel rail
- rb26 cams
-rb26 coil packs
-rb26 ignitor box
-rb26 exhaust manifolds
-rb26 new crankshaft seal
-rb26 cam gears
might even have oil squirters too
Update
still have:
-rb26 standard rods
-rb26 fuel rail
- rb26 cams
-rb26 coil packs
-rb26 ignitor box
-rb26 cam gears
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
