I got a warranty on my stagea when i got it and want to get it looked at why its not running properly.
I've rang them and they have given me 2 companies over the last 2 days both of which are no longer there.
Can you tell me if you know where and when these companies were around.
Evo Motorsports
98 Newcastle st
Fyshwick
Fast and Furious Imports
52-54 Kembla St
Fyshwick
I feel I'm getting the raw end of the stick on this!
Thanks
I rang them again and was told Autoco in Phillip and Mcguinnis motors in fyshwick.
I spoke to the mechanic at mcgunnis and he told me he cant help as he doesnt have the equipment.
I rang AWN back and they said how did i get Autoco information and I told them the guy I spoke to and yet he didnt put it in the information.
I an taking it to G&S Auto Repairs regarding it.
I'm making sure I document everything just incase they try and screw me over on it!
if anyone has had similar problems let me know!
I've heard varying reports about aftermarket warranty contracts - although nothing about AWN (unless it's a rebadged outfit).
I'll be interested in the outcome of your predicament.
I once signed up for one type whilst buying a second hand Honda thru' Larke Hoskins - but nothing went wrong with it. :banana:
as they say a warranty is only worth the paper its written on.
when i bought my car i had some warranty thing on it that came from the dealership. 3 weeks after it arrived a fues blew causing all power to shut down while sitting at 100km/h on the highway. managed to pull it off the road just as it completely shat itself and stalled. tow truck home and a mobile mechnic fee later it was 100% again. sent them the reptort for what happened to be refunded the money under warranty to be told "we dont sell those types of cars nor cover them" before they hung up. oh and the car was 100% standard at this point not even seat covers lol
take it to someone you can trust that deals with that type of car and has previously worked on the car. let this company know that people they request arent willing to touch the type of vehicle and get them to approve it in writting.
if its only something small just pay it and move on. if its big send it back to the place of purchase or threaten legal action for selling something unfit for sale.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
