Hi guys,
Just bought an exedy heavy duty button clutch and am starting to hear stories about them destroying RB25 Boxes..
Anyone have any bad/good experience with one?
Would hate to rebuild my gearbox in the future when all i needed to do was just buy a heavy duty :)
Cheers.
imho, if the car isn't being tracked very regurlarly, driven daily etc. a heavy duty will suffice. it also depends on the mod level and power of the car.
a friend of mine is in the process of replacing his clutch in an '05 STI, the workshop recommended he get an exedy standard spec clutch for his 6 speed. He runs 220awkw. According to the workshop, especially with an awd system that installing a heavy duty will increase strain on the rest of his driveline. Rebuilding a 6spd STI box costs an arm and a leg... I would rather change my clutch more frequently than have to go through the process of a rebuild!
remember the weakest link is what will go first... so generally speaking the driveline will cop more of a beating as opposed to the clutch when you upgrade to a brass button or stronger. again there are many variables in it.
good luck.
Edited by trel
Apart from being a prick on the street taking of from a stand still there's no problem using a button clutch on an rb25 box. You can do damage to an rb25 box with just about any clutch if you have no mechanical sympathy ei. dumping the clutch at 7000rpm to get bitches or flat shifting gears to beat a sik dosed up vl.
I had one in front of my 25 box and it didn't break the box, more 2nd gear clutch drops and stabs than I can count.
Aslong as you don't have too much traction, you shouldn't really be breaking things.
yea with a 2wd you shouldnt have much trouble because theres far less grip so the tyres are often the weakest link. on a 4wd theres far greater traction so the gearbox takes a lot more strain on the hard launches. also given that the exedy clutches have sprung centers thats always a good thing when your wanting to make drivelines go the distance. the solid center clutches are real harsh on drivelines.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
