Ok what we have here is a R32 GTR rolling shell with full interior all panels and glass complied registered.
Originally I planed on removing the ABS, air con and manual gearbox, stripping the engine bay and re spraying and putting my complete set up in with all wiring hidden and full auto but have since lost interest. All I got up to was stripping the bay, welding majority of holes and high fill. The ECU runs a Map sensor so the original air flow meter plugs have been cut off the loom :P, but the rest of the full loom is there, boot cable is broken so will not release form in car but fuel release works fine, also rust under paint on driver door bout the size of 20 cent piece
So heres what you do and don’t get,
DOES NOT INCLUDE
Engine
Gearbox (can supply R33 GTR box with blown 3rd gear)
Intercooler
COMES WITH THE FOLLOWING BUT NOT FITTED
ABS unit or front brake lines
All A/C components (may be hard to fit as lines to heater box have been cut with hacksaw)
Brake booster and master
Clutch booster and master
Rear Diff fully reconditioned new bearings seals
Blitz blow off valves X2
HKS super dragger exhaust cat back
All front guards lights, front bar everything missing from pics 3 & 4
Paint (for engine bay)
COMES WITH THE FOLLOWING FITTED
R32 GTR wheels with Re55 semi slicks
All Brakes
RDA slotted discs
QFM K750 pads
HKS hypermax II coil overs
Autronic SM4
CDI 500R
Advan surge tank
Bosch 040 in tank pump
Bosch 044 ex pump X2
Supporting Fuel lines
Hi cas lock bar
Battery in the boot
All interior in pretty good condition apart from usual bubble in dash.
Feel free to PM me anytime with any question or queries, any photos just send email address and I will forward them.
also note im possibly willing to separate some parts if the person buying does not require them, BUT the interior and body panels will NOT be pulled apart.
Cheers
located north/west suburbs Victoria
$12000ono
Please do not tell me you can get a complete running GTR for 15,000 im not interested.
https://www.sau.com.au/forums/topic/340951-r32-gtr-rolling-shell/
Someone could buy this, buy my engine and box and vola gtr for the win!!
good luck with the sale mate, if i had the money i'd be doing exactly what i said above!
sounds like a plan although i will have a complete engine for sale later next month as well that was built for this car.
if u split im interested in the wheels with the re55s....how much tread on those??
cheers.
will keep posted about the wheels although i would prefer to sell them with the car as then it wouldn't be a rolling shell.
and to all the people asking bout the fuel set up if i do end up separating it i will post it on another page separately so we can go from there.
but at present i am not separating anything just yet.
cheers
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
