http://www.trademe.co.nz/Trade-Me-Motors/C...n-328966931.htm
Im pretty sure they have sold the cvt boxes a long time ago but you might get lucky and they may have a cvt ecu...dunno.
Possibly contact an ecu specialist.. i think plms developments over there may be able to help but not sure if they do anything other than engine ecu's.
What a champion you are mate! Thanks a million! :)
I'll get in touch with them to see if they can sort me out.
Thanks again!
What a champion you are mate! Thanks a million! :P
Thanks again!
You should let them know if they can fix it then they may have some more customers if it ends up being a common fault on the cvt cars awell.
Maybe some of the autos might fail from this issue aswell who knows....
Strange though that the cvt ecu (that you would think would be different) possibly has the same issue as the autos....
****************************MAJOR UPDATE & CONCLUSION************************************************
YES! Finally fixed! After a month of horror and a long list of possible culprit, I finally figured out what was causing the problem.
The problem was...(drum roll) :FAULTY SPEED SENSOR
After spending a week at Tech Transmission with no end result and spent close to $500, I went and took the car to Jamie at Autoworkshop at welshpool cause i couldn't get an appointment soon enough with Fabcar. He hooked up a scan tool, recorded the datalog and told me to go for a drive. As soon as the car was jerky i took a look at the scan tool and the vehicle speed sensor was going haywire. Jumped from 50 to 75 dropped to 4 then finally made the transmission go on limp mode. Sure enough after that he retrieved a P0720 (Vehicle Speed Sensor) Error from the TCM. He had a wicked scan tool.
Got a replacement from Nissan ($300) and fitted it in today. Problem = Gone :blink: I'm so happy i can eat a horse.
Here's the part no for the speed sensor: 31935 - 5P002
I hope this info would be useful to anyone who's experiencing the same problem.
Thanks to Jamie & Brett at Autoworkshop who diagnosed and tested everything on the car. Thanks to everyone here who’s helped.
Sorry for the long post, i'm just too excited right now, My baby lives again! :(
Edited by dodes47
Got a replacement from Nissan ($300) and fitted it in today. Problem = Gone :ermm: I'm so happy i can eat a horse.
Sorry for the long post, i'm just too excited right now, My baby lives again! :D
Thats great you got it sorted and gave the details on the problem and solution it just shows how important a good scan tool is with these modern ecu's.
I want to get myself a consult3 or equivalent at some stage.
  • 1 month later...
Doddy
I think I have a similar problem to what you had. Mine starts to jerk a bit then the tacho goes to 4000+ and stays there. No matter what gear i put it in, the tacho does not change. It's as though I'm driving in 2nd gear. Only way to get back to normal is to stop the car and restart.
Did you change the speed sensor yourself. If so was it much hassle and where is it located?
Bob
Bob
It sounds similar. But my tacho will go up as high as I want to rev it. My gear will get stuck in 2 or 3. While u may have a speed sensor problem, it could be something else as well.
My suggestion is take it to a good mechanic with a good scantool that's able to talk to the ecu/tcm. It should pull up a code You need that code to go on. Don't make the same mistake I did and try to guess the problem.
Btw the speed sensor is located on the gearbox itself. There's two of em. Input and output.
Goodluck let us know how u go
hey wheres the speed sensor located
my cousins car is going through the problem in the limp mode and hes been to so many work shops and when they scan the car it comes up all dese codes which cant be erased and it has nothing to do with the solenoids ay but the codes said it does
P0720 VEH SPD SEN/CIR
P1762 D/C SOLENOID/CIRC
P1752 I/C SOLENOID/CIRC
P1757 FR/B SOLENOID/CIRC
P1772 LC/B SOLENOID/CIRC
P0745 L/Press SOLENOID/CIRC
Ok. Is the car a GT8 or 5sp Auto? Mine is a GT8. So while i'm sure it's exactly the same electrical wise,i can only give you advice based on my transmission.
I'd say that because the Speed Sensor code is at the top of the list might as well give that a fix first.
I recommend taking it for a test drive with the scan tool hooked up and logging the input from the speed sensors and the solenoids. When the problem occurs and the car goes to limp mode you'll definitely see what's causing it in the scan tool.
In my case the speed sensor started going haywire and giving erratic data to the ecu. That's why my car went to limp mode.
The speed sensor is located outside of the transmission housing itself. You need to have good access to the bottom of your car. The input is at the front and output (most likely the culprit) is at the back. You can't miss it.
If you wanna take a shot at fixing this your self firstly check the harness and continuity for the speed sensor (a multimeter would help) if you can rule this out then call any nissan dealer in your area and get a hold of this part : 31935 - 5P002 (Vehicle Speed Sensor) Picture attached.
The input and output uses the same part. So you can swap the input and output if one doesn't fix the problem. This should set you back at least $300.
Goodluck, post back when you have problems/result :thumbsup:
fanx for the the info , its a 5speed auto box
scanned many times and try deleting it & within 5 secs after deleting it , it pops straight back up
will take a look at the sensor first ay, deyv took the whole sum down and check everything and every code and box seems fine so duno wats nxt man
will keep u updated ay
cheers
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
