ok this is going to sound stupid and very fast and the furious. but since insurance is not in my favour rice at the moment is the way to go.
im looking at getting a nitrous bottle for display at car shows. but his has made me decide why dont i do something with it.
everyone knows about the purging of the r34 at the beginging of 2fast2furious. thats what im after. i realise i probably dont need a nitrous filled bottle to get this effect and in the end it probably wont be. but how would the system be setup to purge ie parts, lines switchs and crap. any ideas.
~sits back and prepares for the payouts~
https://www.sau.com.au/forums/topic/34105-nitrous-purging/
  • Replies 114
Theres an article on the ZEX system in a magazine.. not sure if its Zoom or HPI
but its one of them
u can get an extra purge system with it for like another $100, it allows instant fresh NOS allowing better times.. not just rice look
it sprays out basically where ever u put it
in this one they put it coming out of the windscreen where the wipers were
https://www.sau.com.au/forums/topic/34105-nitrous-purging/#findComment-683856
Instead of just wasting it you could get an Ntercooler kit from Nitrous Express. Basically its that ring you see in front of the intercooler on the R34 on 2f2f. It sprays NOS (or whatever else you have in the bottle) on the intercooler and as the pressurised gas is released and hits ambient temperature air it has almost a "freezing" effect so will dramatically drop the temperature of your intercooler core, and as such, drop inlet temps.
Then also on this system, you could have a purge valve hooked up so you could rice it up when you want too, but also have it in there doing something useful. Also instead of filling the bottle with NOS, just use CO2 as its a hell of a lot cheaper and has the same effect on the intercooler.
https://www.sau.com.au/forums/topic/34105-nitrous-purging/#findComment-684036
if u want that effect. you will need to buy two purge N.O.S kits from a N.O.S dealer.
very simple to install. everything comes with the kits i belive.
used to run a single one on my old car (but i did actully have a nos kit)
rember a tank of nos is 80$ and depending on how much u will purge it out it will be wasting money.
still if i saw it on the STREET i would not race you.
https://www.sau.com.au/forums/topic/34105-nitrous-purging/#findComment-684046
Champion!!!! exactly what i'm after... i remember seeing one of these from a link on one of the forums somewhere...
How much are they?... where (IN AUS) can they be purchased....
Atleast these perform a duty.... lol... not TOTAL rice :)
Also, where do you get CO2 refills?
https://www.sau.com.au/forums/topic/34105-nitrous-purging/#findComment-684128
Aww come on, what about the electronic B.O.V. for N/A motors? Surely that's gotta come in at least a close second?
Nah... those Plastic intercooler kits for that...
'All important turbo look'
they would HAVE to be there too :headspin:
https://www.sau.com.au/forums/topic/34105-nitrous-purging/#findComment-684668
not if we stand close enough to the purge :P
The stuff the dentist's use is alot more pure than the industrial NOS.
I used to work at a lab and every 2 days the BOC gases truck used to change a stack of Gas bottles and 1 of them being a big ass bottle of NOS. We used to use NOS for cleaning the precision instruments. I always wanted to pinch 1 of the NOS bottles but it was to big to fit in my Cortina. :)
https://www.sau.com.au/forums/topic/34105-nitrous-purging/#findComment-684680
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
