I never once said I did that on public roads. That's just stupid and irresponsible.
Just how I read it :)
Getting the car tonight. Compression check, spot on. Rego check - PASS!
I put the stock rims on, and all was fine.
Number plate lights are out, and so is the wing light, but it was passed - just was told to fix those - as they are things I'd get booked for if drove it like that.
So now can somebody tell me how to fix/replace the lights for the wing...?
The wing lights are LED's yeah?
EDIT: Ok pending pass, i gotta fix numberplate lights and wing light.
It may just we wiring. I'll get somebody I know to take a look monday.
Simple enough fixes.
Took it to : Premier Automotive Repairs, 5 Winchcombe Lane, Mitchell - 62428450
Great guys there. They replaced one of my wheel studs that was stripped on my Pulsar also.
NP, I don't want to be thought of as a fool or irresponsible or get myself banned for something coming across wrong.
yeah I think so... might just be wiring, not at all sure.. Just gotta take a look and fiddle and see if can sort em out, asap. Least those fixes won't cost me a fortune.
Oh they did note "Advise: exhaust height at 100mm". Rear exhaust as it curves under the rear axle it sits at at 100mm, long as as I don't put to fat bastards in the back it's all good. Plus the suspension is stiff enough any way.
nononononono, wherever I went Andrew, it was about as close to the DIY car wash in Lanyon as you can get...
That's the place.
Thats what i thought the 1st time, google lied to me the bastards lol, its good but, like 2mins from my house :)
Hey, can you guys help me better understand the differences between S1, S2 and S1.5 cos this is a S1.5 and has elements of both together. I read the thread on the differences between S1 and S2, but still bit lost.
I think I read somewhere that s1.5 was just s1 with factory options that s2 came standard with, like ABS and airbags....I'll let someone clarify though
Edited by Trozzle
ah fair enough.
More or less, no difference. Coils are old enough that their original quality is negligible as they're probably about to fail anyway. CAS probably wouldn't make much difference if any. Turbo....well, same sorta deal as the coils - but if my series 1 turbo is anything to compare to, you won't have any worries running it at 11psi all day every day, which is just shy of hitting R&R anyway.
Thing is, this one has the S1 front grill, and lights, S2 rear lights etc, but S1 Grey bar with SKYLINE on the back.
Thats all I really knew for sure.
It has NO abs nor does it have either drivers or passengers airbags.
Not sure if actually is S2 engine or not (turbo, coils etc)..
I have one pending problem that discovered this arvo when collected the car back from the mechanics... They'd not hooked something back right and now it's misfiring.. So gotta take it back and make em fix it in the morning... Damn bastards. This is why I don't like going to mechanics.
We had a really good look and can't find anything, so gonna have to get em to strip it back to the plugs like did today for the compression check, and they better have it sorted for me. I'm so pissed off.
Edited by J'son
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
