Yeah cool cool. But curious about if really is worth spending the $50-59 bucks on the 5L for some those brands vs, things like Castrol and Shell etc that can buy from Auto Barn, Super Cheap etc... I want to be changing the oil every 3months of 5000kms, and $80 each time whilst doing all the work myself still feels a little steep...
I used to run Castrol Edge 5w30 in my SR20DE, and that worked really well, but last couple changes went to Castrol Magnetic 10w40 cos the engine was starting to get a bit more rattly with its age.
it will be worth it mate, it isn't THAT much extra for a much better oil.
Yeah, fair enough call
$20 for genuine filter vs $13 for a ryco.
$59 for the oil vs $40.
I guess the $26 bucks extra for quality and upkeep of such an awesome vehicle is worth it.
filter - just use ryco imo.
In the other thread was saying the genuine ones are meant to be better quality than the ryco ones, but not sure how or if is really true.. But is convenient to get them both together at the same time..
Headlights installed. Boost gauge fixed (not perfectly, and not properly, but on a way that seems to be working successfully....) - should fix it properly later.
Any one able to advise on where the clutch adjustments are on the skylines? I wanna make it start engage closer to the floor like I did in my previous car - if possible.
Almost certain. Well, certainly not worn as much as my pedal movement would suggest.
Autotech advised me after having my car there once that the clutch pedal was adjusted right out, and that they put it back where it should be. It has since found it's way back to where it was pre-adjustment
On my Pulsar all I had to do was find the arm that attaches to the gear box, where the clutch cable attaches, and tighten it (shorten the cable - lock nut + adjuster nut), then adjust the nut behind the pedal in the car to take away the slack that has now been created.
I'll look more carefully at home, and see if can find it.
this is potentially a very dumb comment on my part, but I was under the impression this was a hydraulic clutch in the skyline lol
Which I do not know, and that may be totally correct, this is why I was asking :D
They can be adjusted, but are done differently and I have NFI...
yeah I'm 99% sure it's hydraulic...the adjustment would be on the master cylinder part of the system, probably above the pedal inside the cabin...I'm gonna have a looky at mine this arvo
Yeh confirmed was hydraulic. And thats fine. Now gotta see how the adjustments work, and have a go at fixing it without rooting it. *fingers crossed*
Clutch adusting mission a complete sucess.. It was a bit of a pain in the arse, and had to use pliars to help, but got there.
There is possibly a little too much free play at the top end now, but couldn't adjust it more.. and I'm not positive what the sensors all do on each pedal, but I believe it still depressing it correctly. I'll check again tomorrow.
New headlights look awesome. However the issue with my boost gauge is a bit odd, but prob just needs a new tube.
Well after hanging my head down in the footwell for a good 5 minutes, I can see exactly how all the adjustments work....
From the looks of things, you can adjust the piston (our main concern), the throw as I'll call it (how far down you can push it), and the release (how far back it will come)
I'll be spending some time adjusting mine tomorrow arvo or Saturday morning.
I think I got mine pretty damn good, minimal movement in general, but the adjuster at the top for the pedal position is now maxed out - had to make sure the little sensor button still presses. But It was a pain cos had to use long nose pliars to turn the MC shaft, but it worked in the end. I'm happy. Now just gotta get used to it - again.
Let me know how urs goes.
Edited by J'son
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
