Hay guys Looking at selling my GTR.
Dont really drive it anymore and i feel its wasted.
Everything about this car has been upgraded, Super Fast car with heaps more potential, power has been limited to 350 hp while the engine is fresh, engine and components have only done 5000klm with the gearbox and diff doing a bit more with 15,000 klm. The Car runs a Garret Ball Bearing TO4z high mounted with full 3.75" HKS exhaust (Very Quiet) with a high flow 3.5" cat, has upgraded fuel system with 780cc injectors being feed from a custom twin entry fuel rail, fuel is pumped by a bosh 044 pump and is regulated with a Sard Fuel pressure regulator. The engine is controlled by a VIPEC engine managment system tuned to 15 psi by Mark Jacobson From Godzilla Motor Sport. The car has a full respray in Pale Blue Effect (From 2006 Toyota Corolla) and a standard gtr body kit (not including the wing). It has a Kenwood 7" fold out DVD player and alpine V12 amp with fusion speakers. The Wheels are FZERO Special -Volk rays 18" x 10" and are wrapped in falken 275,35,18. The Suspension is Tein hight adjustable and quite stiff. 4500k Full HID Xenon head light kit has just been installed.
A Full List of Mods and engine work that has been carried out can be emailed to any one that is more interested.
All Offers Considered.
Car can also come with defi boost gauge. Also has a trust extended sump and r33 gtr front diff, currently not on the car but can go with it for a small price.
Im asking for $22500 ono.
Ive spent alot more than that on this car but its time to move on.
You can email me at [email protected]
Or PM me....
https://www.sau.com.au/forums/topic/341666-r32-gtr/
  • 3 weeks later...
  • 3 weeks later...
Hay bud, will get some more pics when i finish putting the cooler and piping in.
running 350hp atw,, that was the run in tune, but pulls harder than that now,
if you want full specs i will email it to you.
PM me your email
https://www.sau.com.au/forums/topic/341666-r32-gtr/#findComment-5659675
  • 4 weeks later...
  • 4 weeks later...
  • 7 months later...
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
