  • Replies 49
this is by far the best GTR i seen for sale in SAU
not the most powerful, but it really done up PROPERLY.
not to mention the brake
the Aragosta Suspension worth DOUBLE what tein or HKS asking.
the HKS EVC pro boost controler is a cool 1.5k
all the mod are using the REAL top of the range aftermarket part.
i have try to make him an offer but it's too low
someone should buy it if u got the $$, won't regret!
yep, saw yours too, nicely done.
Wheels look alot wider than mine.
Will have to catch up some time, my car is going to SAS for two weeks for Z32 80mm AFM's a bigger fuel pump and power Fc as the midori ecu just isnt cutting the mustard. So it will have to be after then. I assume you are from Syd and come up now and again?
I have decided not to sell now and am going to modify a bit more. The car was having cold start problems (i suspect mines air flow meters) so i am going to tinker some more until i want to sell again (prob around december). Prices of 89 gtr's are killing my price, so i will just have to wait for a buyer intersted in buying one 'done the right way'.
Regards,
TG
just a quick question?
i was reading through your list of mods and nothing stands out or isn't clearly defined for of any preventative measures undertaken for the common "oil starvation" problems the RB26 suffers?
could you indicate what has been done to cater for any potential problems? ie. larger sump? sump baffles? oil gallery restrictors? if any....?
cheers,
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
