Tomei 264 Cams 1 Pair $350
OS Gilken triple plate clutch plus flywheel Good condition $700
1 pair Z32 Airflow meters and filters excellent condition $450
Single turbo race pace manafold and gate 48mm turbo smart gate and 4'' single turbo pipe plus oil line T4 Flange $1400
Jun oil pump good condition $500
Standard water pump good condition $50
RB26 Head complete been surfaced, ready to bolt on $1100
Throddle body $300
Oil cooler kit $450
650 Injectors $400
8lt racepace sump new $1850 (with Diff)
V spec Diff $400
v Spec Computer $300
Motec CAS $300
Igniter RB 26 Good Condition $200
GTR R32/ 33 gear box good condition with transfer case $1000
GTR gear box 33 Rebuild $1000 no transfer case
PWR radiator R33 Gtr 40mm core $360
RB 26 Short motor HKS pistons forged rods Prepped crank Standard, Pistons 60 thou over $2000
TE 37 set of four 18x10 Gold anodized GtR offset $2800
BBS 18x 10.5 Set of four Mesh style GTR offset Fitted with four Bridegstone Re 55, 285x18 R Spec 40% tread $2900
New rear adjustable camber arms top $200
Surge Tank and Bosch 044 Motorsport Pump $280
RB 26 Balancer alternator, $350
Rocker covers,timing cover, igniter top cover with HKS power written on top, plus matching intake manafold wrinkle finish, Matching set $600
Selling GTR R33 V Spec Rolling body, White complianced, no motor gear box, no trim $6000
https://www.sau.com.au/forums/topic/341752-rb-26-parts-and-r33-gtr-stuff/
Tomei 264 Cams 1 Pair $350 SOLD
Throddle body $300
Oil cooler kit $450
660 G Reddy Injectors $500 Good Condition Fits standard fuel rail GTR
V spec Diff $400
Motec CAS $300
Here are pictures of all the stuff listed
Oil cooler kit $450
650 Injectors $400
I'm interested in purchasing those parts. Please PM me your contact number and location. Thanks.
Regards,
J
Edited by Jebat
Throddle body $300
Oil cooler kit $450
650 Injectors $400
V spec Diff $400
Motec CAS $300
Surge Tank and Bosch 044 Motorsport Pump $280 sold
Throddle body $300
Oil cooler kit $450
650 Injectors $400
V spec Diff $400
Motec CAS $300
camber arms sold
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
