Hey,
Have been driving my 26/30 for nearly a year now, and there have never been any oil issues.
Just noticed this morning that even after warm up and the 30k drive to work, the pressure wont drop below 7kg/cm2. Usually starts up at 8 and then after warmed up drops down to 3-4 kg/cm2.
This engine has never been flogegd (redline set at 6800rpm), and is driving on a comfortable 10PSI. Car makes about 310 RWKW on 10PSI.
Just wondering if the oil pressure is genuinely high, will this cause any problems??
I have checked oil, plenty in sump.
negligible blow by from rocker covers. Also no excess in cam covers
Water temp is fine, and oil temps dont seem to be elevated when i check.
If this is an issue, where shold i be looking to fix it up.
Thanks in advance guys
Hey,
BUmp
What pump are you running?
The only real issue that could arise is your turbo seals if you havent restricted oil flow to it. If thats all good then dont worry, as the relief valve is inside the engine and too hard to get too to try and adjust. If that is even a problem, could just be your standard ops sender as stated above.
If you really want to be sure, tee in a oil pressure gauge and find out.
Running an N1 , and a GT3582, so when we built the engine, the appropriate restrictor was fitted to the oil feed.
This is a new problem, over the last week - however given taht i dont seem to be consuming any oil, i figure i may just wait until I rebuild the car in 6 months to race.
Thanks for teh help
high oil pressure is your friend - mine does exactly the same & recommended by my tuner & many others that know their stuff!
how else would you expect the oil to enter high tolerance areas such as bearings :ermm:
310rwkw @ 10 psi doesnt really add up
Sorry miss-typed should be 15PSI - Dyno graphs are posted in Hybrid section.
The whole point of the question was - given that my oil pressure has previously sat at 4-6 kg/cm2, was the fact that it is now at 7-8kg/cm2 indicative of a problem, or a faulty OPS.
Popular opinion is taht its not an issue and just a shot OPS.
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
