  • Replies 69
Can you edit your post and remove the location of the meet point. I don't want to open it up to tag-alongs of the unwanted kind. This is why I PM the meet point.
:D
:blink:
sorry mate, just PMed goldzilla to get him to delete it.
was gonna try make this one but smashed the front on the way home from work. :devil:
No!
Damage much?
More PMs will be sent when I can be bothered getting out of bed :blink:
To all,
A small change to the meet time. We will meet at 10.00am for a 10.30am departure ... (not 9.30 meet and 10.00 departure as first advised).
This change is simply because I'm putting on a romantic night for the missus the night before ... and I might keep my testicles longer if I don't rush our checkout from the hotel :P
I will amend my previous posts in this thread to reflect this change.
:P
great run today guys. good to catch up with some familiar faces and see some new ones too.
Had to bail at Aldinga to go home, the daughter was getting cranky.
Hopefully the next one isn't too far away and we get some more numbers.
only got a couple of pics, phone was dying.
Any chance you wanna swap drivelines???
And Ruby...What happened to Delamere Rd, i think somone might have taken the wrong exit at the roundabout.
It was still a good run bu that Inman Valley road is rough as hell.
cheers for the cruise guys was good to meet some of the crew and yeah it would be good to to have another one soon like ruby said today maybe a night time one see if we can get few more ppl out
and big fella your car looks so sweet on the road, are little girl was getting a bit cranky towards the end to but thankfully she decided to go back to sleep feeding those seagulls must have worn her out :P
cheers Rose and jase
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
