  • Replies 78
GenesisR32, yep we're in it and another R33 white will be joining me, that's 5 now :cheers:
p.s.
after the mtn run last thursday which i've done a few 360 :headspin: i realized i need new tyres :boobs: , does anyone know where's the best place to get em, like good deals?
springwood crazy clarks sounds good. Like what Nismogirl said, the car park is big and its possibly the best 'neutral' meeting place for both sides.
how about meeting at 8.30pm, have a little social gathering and chit-chat, put names to faces and then finally decide where we all wanna go from there?
each of us will have different suggestions and chances are that we will eventually be split into smaller groups for cruises, mountain runs, home, mistresses :), etc, etc, ... but at least you will still get to choose whatever activities you wanna participate in on your own free will. :)
i got fedrals on my car, they just wore out :) i had 235's though on 18". hard compund and I have to get tyres today as mine ****ed up >=[
I have Khumo 265 35 18"s on the rear, they were about $30 buck dearer than Nankangs.
I've had them since Nov 2002 and they still have heaps of tread!
Got them from Quick Fit at Capalaba.
I might be in this Thursday,.
Agreed, we need somewhere closer to Brisneyland.
As I said, we will only be at the meeting spot to have a chat, then we will probably head home. So don't get cranky at me for organising it and then leaving. Cause people do that quite often when i've said "we are only going to be out for an hour or so"
*scratches head* Yatala is NOT close to the northside. It would be like a 40 minutes drive, and a 10 minutes drive for yous.... I dont really call that fare :S
lol sorry erin, i was doing three things at once when i wrote that...
as said in above post all ideas to mix things up in the name of fairness and fun is great...
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
