  • Replies 78
GenesisR32, yep we're in it and another R33 white will be joining me, that's 5 now :cheers:
p.s.
after the mtn run last thursday which i've done a few 360 :headspin: i realized i need new tyres :boobs: , does anyone know where's the best place to get em, like good deals?
springwood crazy clarks sounds good. Like what Nismogirl said, the car park is big and its possibly the best 'neutral' meeting place for both sides.
how about meeting at 8.30pm, have a little social gathering and chit-chat, put names to faces and then finally decide where we all wanna go from there?
each of us will have different suggestions and chances are that we will eventually be split into smaller groups for cruises, mountain runs, home, mistresses :), etc, etc, ... but at least you will still get to choose whatever activities you wanna participate in on your own free will. :)
i got fedrals on my car, they just wore out :) i had 235's though on 18". hard compund and I have to get tyres today as mine ****ed up >=[
I have Khumo 265 35 18"s on the rear, they were about $30 buck dearer than Nankangs.
I've had them since Nov 2002 and they still have heaps of tread!
Got them from Quick Fit at Capalaba.
I might be in this Thursday,.
Agreed, we need somewhere closer to Brisneyland.
As I said, we will only be at the meeting spot to have a chat, then we will probably head home. So don't get cranky at me for organising it and then leaving. Cause people do that quite often when i've said "we are only going to be out for an hour or so"
*scratches head* Yatala is NOT close to the northside. It would be like a 40 minutes drive, and a 10 minutes drive for yous.... I dont really call that fare :S
lol sorry erin, i was doing three things at once when i wrote that...
as said in above post all ideas to mix things up in the name of fairness and fun is great...
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
