Hey Guys, new to the forum but have a frew mates that say there's a wealth of knowledge and am wondering if anyone could help mem out.
I own a U12 Pintara which I bought for a second car to run about in when the other half is using our main car. I also bought it becuase I wanted to learn about cars in general and was told it's a pretty simple car to work on etc. I'm thinking of chaning the engine in the near future (purely for shits and giggles) and have been trying to find out as much info on it as possible. Anyway long story short my research led me to a thread that said that a CA20E can be swapped for a CA18DET. Mates have also suggested an SR20 but from what I've read the CA18 and CA20 have the same engine mounts, so I'm assuming that's less messing about over all.
Wondering if there's anybody that has done it and if so what problems there where etc. Also anyone who wants to elighten me with further info that'd be great too. I'm pretty new to the "car world" so don't know a great deal but am a quick learner.
Cheers
Aaron
Edit: sorry this is posted in general maintenance, wasn't where else to pop the bugger.
Edited by Slarty_Bartfast
https://www.sau.com.au/forums/topic/342799-u12-engine-swap/
You'll need to check with Vic transport for modification guidelines regarding engine swaps to ensure you meet the necessary requirements (although this one shouldn't be a problem). If you're not already I suggest you also become a member here- www.antrx.com
Edited by doo doo
https://www.sau.com.au/forums/topic/342799-u12-engine-swap/#findComment-5529608
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
