Hi guys,
I have R33 GTST parts that are lying around and am looking to off load them at cheap prices.
I will be very firm with my prices, as they are already very cheap
Depending on the item and how many you are taking off my hands,
I MAY CONSIDER Reasonable/Fair offers, (low-ballers and time wasters will be ignored) & possible delivery at buyers expense.
All parts can be PICKED UP FROM SOUTH MORANG, MELBOUNRE, 3752
Let me know if you are interested in anything... You can PM me, as I am on this site daily.
Thanks, Ben 0422 782 888
EXTERIOR PARTS
R33 M-Spec side skirts L+R, plastic, been repaired, needs respray to match car PAIR $60
series 2 wing/spoiler WHITE, brake light not working, Good condition $60
series 1 wing/spoiler BURGANDY, brake light working, Good condition $30
R33 GTR wing/spoiler BURGANDY, Excellent fit, aftermarket, no brake light exists in structure, fibreglass, few hairline cracks, (requires little filling, sanding and respray) $45
series 1 Bonnet BURGANDY (no dents or rust, requires respray, clear coat has pealed) $60
series 1 Front bar L+R Indicator/fog lights, Very good condition $50
series 1 RHS headlight, All brackets are fine, Little fogging/Yellow $70
series 1 LHS headlight, All brackets are fine, Little fogging/Yellow $70
Headlight plastic lenses can be easily repaired to as new condition with restoration kits, they cost around $30 and are industrial quality, all you do is clean, sand/polish untill clean and clear, clean again, then apply the UV protective coating, so it does not fog up again BOTH HEADLIGHTS FOR $120
R33 Stone guard, under engine, Good condition $15
R33 GST-T Cold Air Box Cover which is designed to house pod filters.
This assists to reduce power loss caused by the sucking in of hot air from the turbo and the engine bay, Has been used (2,000kms) Very good condition $70
Series 1 Clear Center Ganish, (between tail lights) reads "skyline" on it $30
Series 2 HEADLIGHTS L+R, Lenses have no fog, corner of lens cracked off both (8mm near parker light) have bits to replace, frame and brackets of both headlights are in good condition PAIR $270
Series 2 HEADLIGHTS L+R, Lenses have no fog, good condition, Couple of brackets broken off, still fits and holds on car fine, (have 2 of the 4 brackets broken off to replace with plumbing glue, silicon can do the rest) PAIR $250
REQUEST MORE PICTURES IF INTERESTED...
Items are in South Morang 3752, Victoria.
Get in quick... cause at these prices they won't last long!
Call, text, or PM me on 0422 782 888
Thanks, Ben
Thanks, Ben
x1 Driver Side Series 1 headlight, PENDING SALE
Cold Air Box, PENDING SALE
Rear Center Garnish, PENDING SALE
Thanks, Ben
Hey Ben,
I'd be keen on the air box if the sale falls through. I'm from South Morang too! Please update the thread if this item sells.
Cheers,
OKAY, UPDATE ON THE STATUS OF PARTS:
R33 M-Spec side skirts L+R, plastic, been repaired, needs respray to match car PAIR $60 PENDING SALE
series 1 Bonnet BURGANDY (no dents or rust, requires respray) $60 PENDING SALE
series 1 RHS headlight, All brackets are fine, Little fogging/Yellow $70 SOLD
This assists to reduce power loss caused by the sucking in of hot air from the turbo and the engine bay, Has been used (2,000kms) Very good condition $70 SOLD
Series 1 Clear Center Ganish, (between tail lights) reads "skyline" on it $30 SOLD
AND, AN UPDATE ON THE SERIES 2 HEADLIGHTS...
NOTE: The cheapest brand new factory set of Series 2 Headlights would cost you $1250 + Postage...
(SET 1) Series 2 HEADLIGHTS - PAIR $270
RIGHT/DRIVER SIDE: Lense has no fog, corner of lens (near parker) has split/cracked off (8mm), all still there, holding on and intact, easy fix with plumbing glue, plastic lense (inside of parker area) must have had a larger globe touching it and, slightly melted it, has not even come close to going through, and honestly can't notice from outside, headlight frame and brackets all intact and in good conditiion.
LEFT/PASSENGER SIDE: Lense has a little fog, corner of lens (near parker) IS NOT cracked off, frame and brackets of headlight all intact and in good condition, missing parker globe bracket (can be replace from S1 or S2 head lights) Plastic lense (inside in front of parker) must have had a larger globe touching it and, slightly melted it, has not even come close to going through, and honestly cant notice from outside
Headlight plastic lenses can be easily repaired to as new condition with restoration kits, they cost around $30 and are industrial grade, all you do is clean the surface, sand/polish untill clean and clear, clean again, then apply the UV protective coating, so it does not fog up on you again for a very long time.
(SET 2) Series 2 HEADLIGHTS - PAIR $250
LEFT/PASSENGER SIDE: Lense has no fog, very good condition, only missing 1 bracket (hole left, easily fill in with silicon), still fits and holds on car well/fine, Plastic lense (inside in front of parker) must have had a larger globe touching it and, has slightly melted it, has not even come close to going through, and honestly can't notice from outside.
RIGHT/DRIVERS SIDE: Lense has no fog, excellent condition, all 4 brackets are broken off, still have 2 brackets to re-glue back on with plumbing glue, 1 bracket is just a metal screw on (easily replaced) leaving 1 hole to fill in with silicon (then it should fit and hold fine), corner of lense near parker has cracked/brocken off (8mm), missing a small part, easy replacment and fix
Thanks, Ben
Thanks, Ben
SHOTGUN HEADLIGHTTTTTTT!!!! :)
Will you sell only RHS? im not sure which one ill take, can i come up saturday to have a quick look?
Sorry mate,
Selling as a pair/sets (Left and Right) Either set one or set two, will not mix or seperate!
At these prices, you can see I'm trying to empty my garage, :D not half empty it. :D
(I would have to say Set 1 is in better condition overall as thats why it is $20 more)
Of course you can come and have a look, I recommend to be quick! Alot of interest
P.S guys... SIDE SKIRTS, SOLD!!!
AND... all 3 wings still available!
UPDATE ON THE STATUS OF PARTS 5th NOV '10':
R33 M-Spec side skirts L+R, plastic, been repaired, needs respray to match car PAIR $60 SOLD
R33 GTR wing/spoiler BURGANDY, Excellent fit, aftermarket, no brake light exists in structure, fibreglass, few hairline cracks, (requires little filling, sanding and respray) $45 PENDING SALE
I WILL NOT SEPERATE SETS, YOU CHOOSE SET 1 OR SET 2, SIMPLE!
Parts are in South Morang 3752, Victoria.
Hurry guys, avoid disappointment, everythings selling very quick...
Thanks, Ben
UPDATE ON THE STATUS OF PARTS 5th Nov'10':
AND, THE SERIES 2 HEADLIGHTS...
I WILL NOT SELL THE S2 HEADLIGHTS SEPERATE!
YOU CHOOSE SET 1 OR SET 2, SIMPLE! TOTAL BARGIN!!!
Hurry guys, avoid disappointment, everythings disappearing very fast...
Thanks, Ben
PM sent re: GTR wing
GUYS, THEY JUST GOT EVEN CHEAPER...
Let me know if you are interested in anything... You can PM me, as I am on this often.
REMAINING PARTS STILL FOR SALE:
series 1 wing/spoiler BURGANDY, brake light working, Good condition $30 NOW $20
series 1 Front bar L+R Indicator/fog lights, Very good condition $50 NOW $30
series 1 LHS headlight, All brackets are fine, Little fogging/Yellow $70 NOW $60
(Headlight plastic lenses can be easily repaired to as new condition with restoration kits, they cost around $30 and are industrial quality, all you do is clean, sand/polish untill clean and clear, clean again, then apply the UV protective coating, so it does not fog up again)
R33 Stone guard, under engine, Good condition $15 NOW $10 or FREE with any other part
Series 2 HEADLIGHTS L+R, SET 1, THE PAIR $270
Series 2 HEADLIGHTS L+R, SET 2, THE PAIR $250
SEE PREVIOUS POSTS FOR PICTURES AND DESCRIPTIONS
Thanks, Ben
Thanks, Ben
Bump...
still got the bonnet?
GUYS, GOING, GOING... ALMOST GONE...
(IF THE PART IS NOT IN THE LIST BELOW, IT HAS SOLD, AS IN, NO LONGER IN MY POSSESSION!!!)
SERIES 2 HEADLIGHTS L+R, SET 1, THE PAIR $270 GOOD CONDITION
SERIES 2 HEADLIGHTS L+R, SET 2, THE PAIR $250 FAIR CONDITION, VERY CLEAR LENSE
(SEE PREVOIUS POSTS FOR PICTURES AND DESCRIPIONS)
SOME SERIES 1 INTERIOR GOING
CHEAP ASWELL...
-Floor mats, all seats, (s2 rear seat) door cards/trims, front pillars, dash, S1 plastic around manual shifter, S1 Center console (elbow rest), 2 side pieces of carpet, L & R only, factory cut for rear strut brace, THAT IS ALL!
Low-ballers and time wasters will be ignored & possible delivery at buyers expense.
GUYS, ALSO GOT SOME SERIES 1 INERIOR FOR CHEAP...
(IF THE PARTS FROM THE FIRST THREAD OF THIS TOPIC ARE NOT ON THE LIST BELOW, IT MEANS THAT IT HAS SOLD, AS IN, NO LONGER IN MY POSSESSION!!!)
CHEAP ASWELL...
-Floor mats, s1 (all seats), s2 rear seat, door cards/trims, front pillars, dash, S1 plastic around manual shifter, S1 Center console (elbow rest), 2 side pieces of boot carpet, L & R only, factory cut for rear strut brace, THAT IS ALL!
CHEAP ASWELL...
Bump
CHEAP ASWELL...
Bump, Bump, Bump them right out of my garage!
  • 1 month later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
