Ok, so i'm posting this up for a mate who is putting a natro 25 with a rb20 gearbox into a 33 for someone and has run into problems with the speedo. he is using a sr20 speedo sender and the speedo is reading double and is hitting the 180kmh speed cut at about 90kmh (i think the speedo is showing 180kmh as well, so he can essentially hit the speed cut near redline in 2nd gear or at mid revs in 3rd). does anyone know a way to fix this? reading through some other threads i saw something about a jaycar speedo corrector unit so will let him know about that, but i was just wondering if there was any other easier and possibly cheaper way to do it. does anyone know of possible senders that will work?
https://www.sau.com.au/forums/topic/342979-rb20-box-into-a-r33/
  • 7 years later...
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
