  • Replies 96
Posted Images
Owen, where and how do i get the pic of Baxter my doggie. It is the best of him i have seen in a very long time!!!! Let me know!
http://www.flickr.com/photos/owenh/5233176105/sizes/l/in/photostream/ , in there you can click on Original if you want; warning, 18.1 megapixel :P
Was a good run in the end after how bad the weather was earlier on, owen could i get you to email me the pics of my r33 the 1st pic would look good as my desktop ;)
As above, http://www.flickr.com/photos/owenh/5233749830/sizes/l/in/set-72157625406056757/
Figured I'd give you guys the easy option first, with the massive image if you want it :P
yea might when i get time during "work" in the holidays ;)
mind u this was all done on my tiny 11" ultra low voltage machine :D
Just whore up a T4L machine :P Even a base model would do the job
lmao yea i was too far in to transfer it all though :( lol f**k that ill just use the clickview dual i7 server :P theirs a reason it has a ati 5870 in it... shhh don't tell the boss ;)
  • 3 weeks later...
  • 1 month later...
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
