Its a 1993 Rb20DET silver top
I had 3 inch exhaust system and pod everything else was stock far as i know.
Is this safe to be running that amount of psi and power with a stock RB20, also is it spiking cus it goes from like 12.5psi to 10psi why is that i really need help as i dont know about this stuff other engine stuff is easy please any help would be great cheers.
Josh
Edited by Resigned R32
  • Like 1
https://www.sau.com.au/forums/topic/343070-is-this-safe/
I'm not sure about what the standard RB20 turbo can handle, but as long as the AFR's are fine then there's nothing wrong with that.
The power does look a tad low though, but that might be because it's still the standard RB20 turbo, which is small :D
https://www.sau.com.au/forums/topic/343070-is-this-safe/#findComment-5532796
yeh thats normal and safe.
i was running 1 bar(14.7psi) through a stock rb20 turbo for 3 years and about 60000ks (had 124000ks on it already when i bought it) and it was still in great condition when i pulled it out.
Edited by battery
https://www.sau.com.au/forums/topic/343070-is-this-safe/#findComment-5532797
Ill have to re dyno it soon got a FMIC on it now try boost worx and see if they can help me out and check the AFR. lol ya i know i want 180 rwkws xD
Really 1 bar whoa nisstune or standard tune? i thought you can detonate the engine at 13psi? ppl keep telling me 7psi is standard tho is hell annoying to get a straight answer argh = (
https://www.sau.com.au/forums/topic/343070-is-this-safe/#findComment-5532826
can detonate the engine at 0psi or 100psi, boost is mostly irrelevant. rb20s run 10psi standard, rb25s are 7psi.
and that boost and power is not going to hurt a rb20
so it is 10psi thanks. Heaps of ppl keep saying standard is 7psi, was scarying me = (
https://www.sau.com.au/forums/topic/343070-is-this-safe/#findComment-5532850
people run 16psi through the stock turbo for years and have no issues.
they dont really make much power over 14psi so i say run it at that and if it blows well its only gonna cost you $100 and half a day to replace one.
if your worried about detonation its best to get the AFR's checked on a dyno which depending on where you go will cost between $60 and $100.
https://www.sau.com.au/forums/topic/343070-is-this-safe/#findComment-5532863
I think im gonna book to see boost worx this monday to tune my fmic and check everything isnt pinging thanks for your help = )
https://www.sau.com.au/forums/topic/343070-is-this-safe/#findComment-5532888
rb20s will run up to 13psi just off the spring depending on intake/exhaust mods, 13psi dropping to 9 in the top end is fine if its been tuned and it looks like it has a decent one, fairly smooth.
Just make sure AFRs and knock is in check, power looks about right, usually see between 150-170kw with that boost and a tune, looks fine to me, 30 minutes on the dyno should confirm everything is fine.
https://www.sau.com.au/forums/topic/343070-is-this-safe/#findComment-5533144
Hey mate,
I reckon you should go and see Shaun @ Boostworx, he's a great tuner.
the graph doesnt really tell all that much? but i'm assuming that you're using a bleed valve to up the boost? if thats the case then the boost curve looks about right, i had a bleed valve on my GTR, it was peaking at 19psi then dropping to 18psi gradually like your's has.
i now have an EBC, it hold 21psi flat all the way to redline, but its cost me! for your aim's i'd say stick with the bleed valve.
as far as tuning goes, if you've still got a stock ECU then get a Nistune, they're cheap and probably best bang for buck ECU out there. I'm running one in my GTR and its great!
if you just wanna check that the car is running okay then throw it on a dyno and check AFR's and whether there is any knock. that's what's really going to kill your engine (excessive knock or lean AFR's)
https://www.sau.com.au/forums/topic/343070-is-this-safe/#findComment-5533449
Ya im gonna go this monday at boost worx got it booked to make sure. Thanks for the info mate helped out = )
kinda hard to tell without a AFR graph whats going on.
looks ok though - you mention getting a tune with a FMIC - what ECU?
Standard ecu man
Hey mate,
Ya ive booked it for monday to see him to make sure my car isnt pinging or spiking and to tune my fmic to the car. Also i dont have a bleed valve at all and standard waste gate which is weird
https://www.sau.com.au/forums/topic/343070-is-this-safe/#findComment-5533878
    • Can you help!   Can you tell me a few places you got your Flex Fuel Kits installed in Sydney The only one I know of is Tunehouse. Thanks in advance!!!
    • Yea my thought was tighter engine when hot is more load a poor ground connection can't take. On that note, I had time to check my driveshaft verical alignment tonight, it's +2 and -2 at either end, so thats perfect and how I had set it up last year. What would be the easiest way to check horizontal alignment between my diff and transmission? I can think of a few ways but they're all complicated and I feel like I'm overthinking it. I'm hoping it's that as I can't see any other reason why I have developed driveline vibration since I put the motor back in.
    • Thank god. I thought I was the only one, nobody seems to mention this (cause nobody really goes this far in Sedan land). The car's track is 10mm wider at the rear, which explains why the rears sit a little further out for the same size wheels. There's not really many options in widebody land for sedans anyway - People will just use whatever came out of the box and then buy wheels/spacers to suit. To get it perfect you'll likely need custom wheels with custom offsets if you really want to get it perfect which is what I plan to do, but I also plan to utilize more of the inboard space for tyres at the rear... which is also something nobody ever seems to do.... OR my maths have failed me after 20,000 attempts and I'm about to make huge mistakes.
    • What colour is that?  A mate of mine went red/black on his SLR5000 tribute recently also.  And yes, also glad to see this still progressing albeit slowly.
    • found a company that makes a flat gauge face 3-d printed mounting base kit to eliminate the dished style gauges. if anyone else is looking to do the same https://www.dashfreaks.de/shop/flat-dials-holder-nissan-skyline-r34-gt-gtt/
