hey jake...everyones just taking a piss out of you...lol...its just this topic is covered to many times...try searching the forum before posting... :P
lol i can see everyone else is :devil:
but birds really dont like me lol :D
yeaa thats my bad probs should have checked that out sorrry
Wow.. never knew you could avoid where they place RANDOM Breath Test..
Better to leave those P Plates off.. just add to the shit the cops can get ya for..
ON a second note: This is the second tool to post stupid ass shit.. i hereby propose
hks33 = La Bomba
SweetAsBrahh = La Bomba..
2 down.. 165 users to go..
Nah ever saturday they have this RBT that they have in the one spot an they are always there so most peeps i know just go through the caltex an your all good lol so yea :P
Consequences of driving a skyline....
#1 Spun Bearings
#2 busted ring lands
#3 broken oil pump
#4 blown standard turbo(s)
#5 f**ked coil packs
#6 11ty threads on SAU about what turbo should I get
#7 11ty Threads on SAU about Missfire at 4500rpm
#8 11ty Threads on SAU on how do I remove my turbo so I can drive on "P's"
#9 11ty Threads on SAU about what happens if I get caught driving a turbo on "P's"
but birds really dont like me lol :P
It's not that I don't like you, I just don't like your face.
Nah ever saturday they have this RBT that they have in the one spot an they are always there so most peeps i know just go through the caltex an your all good lol so yea :devil:
Random = random. It's not random if it's there every week. An RBT is when a police car pulls you over and gives you a breath test on the spot. There's really no avoiding a police car randomly pulling you over, unless you enjoy spending time in court.
errr.. ok.. i didnt know RBT setup at the same spot and only one of them.. next time i'll be sure to just turn around when the cops have an RBT.. i mean its not like they chase you or anything.. seriously.. which govt let the retards enter australia?
Aww they do here they usualy have this purple ford rx6 that sits facing the oppsite end of the traffic to wait for the fellas who turn around. Last sat i was driving past an i noticed some dude doing a illegal u-turn at the lights an the xr6 went after him.
an actualy ive seen them do it on that cop show "RBT" i think its called.
haha wut.. so they won't chase you for illegally passing through the servo station then eh..
noticed you arent getting a turbo anymore then..
[200] is here.. waits for abuse..
Im on my red P's going for my greans in like 3 days. If i get pulled over what will happen to me and the car?
Cheers
You'll probably get some of this:
Edited by nick_7g
I cant believe people can be so stupid...
as birds has also stated, what happens when you run up the back of an expensive car? might not even be your fault... but you have to pay as you were behind.
and insurance will not cover a p plater in a turbo car
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
