  • Replies 181
All PM's replied too!
Door cards $60
Window control $60
Rear seat $200
Fuel Pump $100
Kick panels $30 each
Boot trim $50
Sun visors $30 each
HICAS Computer $50
A pillars $20 each
Interior lights $40
Glovebox $30
Centre gauges $80
Rear windscreen wiper + motor $40
Passenger side tail light $60
HEAPSSS MORE STUFF than that but thats all i can be bothered listing so ask away, need it all GONE!
do u have the afms if so wat condition are they in
i pm you but no reply
AFM's are sold mate, sorry im bombarded with PM's and can't reply to all cause of flood control
Hi Brodie
Stock air box
Stock boost solenoid
Stock BOV and piping
Posted to Sydney 2011
Cool,
Andy
All of those are sold sorry mate! Anything else u need?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
