Hey anyone know what size injectors and airflow meters are in the stagea when is standard.
I just got mine tuned with a power fc and its at 95% injector cycle on 14psi making 190kws?
Does that sound right. I would have thought the r33 GTR engine would put out more????
https://www.sau.com.au/forums/topic/343151-stagea-autech/
what are the AFR's? sounds pretty low to me.
mine makes 205awkw on 11psi.......and it's an RB25det :P
oh and in other helpful info, the GT-R injectors are 440cc and should be good for 300kw
Edited by SMOKEYC34
https://www.sau.com.au/forums/topic/343151-stagea-autech/#findComment-5534036
Just looks too low to me. Does it feel fast? My RB25DET with an R33 turbo highflowed by GCG was making 245awkw. Unless there is an obvious fault I would suspect poor tune. Do you want to PM me the name of the tuner/workshop? AFRs look conservatively rich but that's not a bad thing. Apart from fuel supply timing would be the obvious thing to look at. The difference between a good tuner and somone who just knows how to operate a PFC can be huge.
https://www.sau.com.au/forums/topic/343151-stagea-autech/#findComment-5535104
It has conservative AFR's (perhaps a bit conservative) so some of the power is to be gained by leaning it back towards 12:1 but I suspect there is more to be gained in ignition timing to wake it up earlier.
RB26's respond well with adjustable cam gears so if you are getting it retuned then investing in some time on the dyno setting them up can reap some good rewards.
Unfortunately sitting here in our loungerooms we don't have all the info so there may be other issues hence the need to take the car to someone with a known history of great results with RB's and PowerFC.
https://www.sau.com.au/forums/topic/343151-stagea-autech/#findComment-5535110
Hei good to hear you got an autech. Did you change your cam gears? My rig runs everything on standard exscept for the power fc, cam gears. everything else is standard. My signature says it all. Where are you located at?
https://www.sau.com.au/forums/topic/343151-stagea-autech/#findComment-5535218
Well i can think that maybe the car had alot more work/bolt ons and i wonder if the importer or the compliancing workshop threw some less than standard parts into it to sell it. I think i might try and get some bigger injecters, fuel pump and fuel pressure reg then maybe look at getting different airflow meters. what are your injectors running on your standard autech?
https://www.sau.com.au/forums/topic/343151-stagea-autech/#findComment-5535416
Shouldnt be. You can take a look at the engine compartment and look at the nuts and bolts wheter they have been opened before. As for the injectors and the fuel system all is standard. If i remembered correctly the injecors are running close to max.
Here is the thing. For my rig parts that i ave changed for increase peformance. Drop in replacement k&n filter, cam gears in/out, 3" exhaust system, power Fc and that was it. I got 236kw @all wheels. I was running mobil fuel when tuned. Everything else is standard, fuel system, engine, boost controller, clutch.
https://www.sau.com.au/forums/topic/343151-stagea-autech/#findComment-5535469
    • Congrats on the career change!  I did something similar at the start of the year too, left IT / corporate after nearly 2 decades. Soooo when's the motor coming out for the spark plug change?
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
