  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
safety...
yeah, thats the other possibility i guess, running to rich and just flooding the plugs so they get clogged easily. Although i would have thought it would be leaning out. Actually Cyrus: why *are* you trying to go above 10psi with stock cooler and stock ECU = badness.. summer will hurt you.
safety...
well this not only happens at over 10psi, on rare occasions it happens around 7-8 psi, under open throttle conditions, meh I dont really want that, be good if I could turn the turbo off for a while as i will be riding to work for a couple weeks seen I want to pay Beau off as fast as possible.
Damn petrol being>$1/ltr, sucks to own a turbo car :P
search function is my freind:
In my opinion the big advantage of the SAFC 11 is the ability to tune part throttle A/F ratios separately from full throttle A/F ratios. With earlier versions the tuner had to compromise, eg; too rich at part throttle to get full throttle OK. This affected fuel economy if you compromised rich and risked engine damage if you compromised lean. With an SAFC 11 you can have a bit of cake and eat it too. Not all the cake though, that's full ECU (as in Power FC) territory.
The SAFC1 's have great extrapolation though, so the lower number of load points is not as big a handicap as some make out.
Skylines run closed loop, therefore if you don't boost the car the AFR's should be 14:1 and won't use much petrol:D
Yeah I am running a turbosmart bleed valve boost controller and after this thursday i am going to turn it down as low as i can go, which is 7psi according to our local hero, i didnt really understand what all this talk about wastegates and dunno really how turbos work, so I didnt argue with him :P
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
