  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I wish you guys/gals lived closer, cause I'd come round and help
Ok then ;).. we had a play around a couple of hours ago .. riddle me this:
- coil packs swapped for complete other set
- spark plugs seem to be "about 0.8mm" (left feeler guage at home - oops) and were all fairly recently replaced.. NGK BCP6RES which i think come out these days stock at 0.8
- no obvious air leaks, split, or disconnect vacuum pipes
Which in my mind only could leave?
- Timing slightly out (couldn't check)
- not running cooler or aftermarket management which i know is a bit iffy at 10psi (although apparently it does it at stock boost levels too)
- ignition module (doubt it)
... OR ????
Running about 10psi boost, few random misses at around 4000rpm.. but can "push" thru till they start appearing at 5500rpm or so again. Not massive (heard worse) but enough to shit you when going hard.
So Dr Paul - what is your prognosis?
This is Ska's ka (oo that rhymes)... nah.. no SAFC .. no nothing - that is why I think its maybe a bit iffy even trying to wind the boost up on that setup. No real sign of audible pinging though. Actually almost seems to be the opposite... could it could be just running a bit rich, flooding the cylinders??
0.64mm ? interesting... he could try that.
I always used to run BCP6RES w/ 0.8mm on the rb25det and never had miss issues 10degrees or 35degrees.. but i did have a big front mount and SAFC.
well at least i found out my "spare" coilpacks work.
    • I used to have Walbro 255's when they were a pretty common update. (or were they 044? 040?) In any case I had a dirty tank. I thought the tank was good, but I would find the filter would clog in maybe ~50km of driving. If the issue persists, well, your fuel system or tank has crap in it that the pump is sucking up.
    • Hi. Ok thanks for the info. I/we do not know what tune is on that Nistune ECU so it is why there is stock ECU and that Nistune is for later when the car is done. I have guy who tunes Nistune and other ECU so i will then take it to him to see and properly tune for the car   And for the update. On 99,9% it is bad fuel pump. Which is wierd cuz it is like 2 years old(brand new walbro 255) and that filter (also brand new) was dirty.  I was alwaya pumped premium(100) on very good petrol station so i dont know how is that possible...
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
