i wont parade my fun round the office - im a lady :D
hmm maybe i should keep working here - all the old girls here ar egetting men ..... if im still lefto n the shelf at age 50 i guess this is the place to work haha
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
