  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hey Paul Niz going to have to catch up with uz when I come over I should be coming in Feb next year going visit a friend in colie I think thats it ;)
Cool ..... dont forget to pack ya ugg boots :)
Nah come n have a beer with us! :D
3 1/2 hours .... collie is country .... im a city dweller :) you'll have to come this way before gonig to collie anyway.
We got a good drift circuit down in collie tho!
Ah cool yeah flying in for the week & going to just be catching up with a old friend :D I have not seen her for a long time, its been about a year now so yeah time for a catch up & find out whats new ;)
:Oops: ah yeah summer ah hhhhhmmmmmm I am a bit slow tonight??? :Oops:
not in Feb Oz :D be pretty damn warm - but Collie is south and so in winter its pretty cold - not too mention its country so ugg boots are always fashionable :bahaha:
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
