  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
DAMN I wish mine was that cheap, but then again, that would make it a 31, hmmmmmmmm maybe not :(:D
hey cyrus it only goes up 400 once I put the s/c on it I asked & they said being I have a rating 2 & the car will be other wise stock (wink wink) it will be ok for them to cover me only thing is the excess goes up to 1700 if the smash is my fault
Are you still sick Mikey? far out what have you got man, dont give it to me!
yeah cyrus amn never been this bad in a long time I can hardly talk my voice comes & goes :D going back to see the doc soo meds he gave me are not working:bonk:
oh shit speaking of doc I better get ready to go
OH and sorry chris but you got pipped at the post with those switches, so sorry, but thanks for the time, I'll try not to bother you guys if I know we wont be going with you, or there is a damn good chance we wont be, I hate wasting other peoples time, sorry bout that!
