  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
lol.. well if all goes well I will probably take some pix tomorrow, post them up.
It's not going to be complied (going to do that mostly myself I decided) for a while, so not going to go anywhere much further than the driveway unfortunately :(
Yeah same here I hate buying pos cars and spending money fixin this and that, rather just spend more money and buy something that is gonna last and stuff.
thats why i sold the line and bought a new car for work i would have loved to keep the line but i didnt want a shitbox ute that would break down on me everyday i went to work so i bought brand new instead
Yeah what you got is waaaaaay better than a pos ute, although I know of some pos utes that just refuse to die, so but still I'd rarther what you got to over a pos ute, but hmmmm add in a skyline and it would be a tough call for me, but you probably made the cheaper decision which in the end would be the right one :(
And no sign of Nexus at the meeting :( NO HUB AND NO CAT5 CABLE MAKES CYRUS something something
Sorry Cyrus I am sick, I had to have the day off work today as well and I never take days off :D
new car is black..
yeah, chris didn't sound too well this morning... Didn't think he would make it.
I yes and no about shitboxes.. they're never anything classy, but parts are cheap, and my last 4 shitboxes have only broken down on me twice.. once for a dead starter motor, and once for a dead cas.. but I do try to choose my cheap crap carefully :(
And if one can do 15 laps of QR without dying they can't be that unreliable :D
yeah i had to way everything up aswell 2 regos 2 services tyres petrol it all was to expensive
Yeah yeah yeah!
You've been out galavanting all over the countryside with that floosy of a big brother of yours! Havent you! Havent you! Look at meeee! :(
Yeah Gordo said you musta been pretty sick, I'll just grab it off ya some other time, no biggie, go back to bed and drink some more chicken soup, it's easy on the toncils as you throw it back up :D
ahh yes congrats cyrus
couldnt get there to vote tonite had my touch semi on
Yeah I'll forgive you this time! :( Anyway there wasnt much voting :D more along the lines of, hey you want to be president, fine there ya go, who wants dibs on treasurer, Bam there ya go, anyone else, oh yeah secretary, cool no probs!
Was pretty straight forward, no real need for voteing, I just suggested it for my sake so that people cant say I didnt get voted in but was appointed the position :D
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
