If you take any number between 1 & 9 and multipy them by 9 the sum of the two numbers will always be 9
(ex: 7 X 9 = 63 ; 6 + 3 = 9)
btw if you are really mathematically inclined you will know why I have chosen Nexus9 for my name, I am such a geek
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
In 1970, an Arizona lawyer named Russel H. Ansie filed a $100,000 law
suit against God. He won because the defendant never showed up in court.
He is still waiting to be paid and accrues 10% interest per annum
The 'y' in signs reading "ye olde.." is properly pronounced with a 'th' sound, not 'y'. The "th" sound does not exist in Latin, so ancient Roman occupied (present day) England use the rune "thorn" to represent "th" sounds. With the advent of the printing press the character from the Roman alphabet which closest resembled thorn was the lower case "y".
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
