  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
weight on? holy crap! best thing. start running or join a Gym. fitness is more what you need. mental toughness as well.
The IT field they offer (OCSS i think) trains you for field networks and cisco CCNA. and they keep training you as well.
I hate everyone !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
