  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
how what happened to me on the way home from work 2day, there was this chik and her bf driving a shity vn commo, and they were passing this old person driving slow around a round-a-bout so i decide to follow them, then we had to go through another roundabout so i passed them and nailled it up tha road, so when they caught up he starts abusing me out his window! i figure he was just jelous of the car. what a **** head. couldnt be bothered arguing with him so i just waved goodbye to him as i turn off. he was pissed!
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
